Protect your high speed network from noise and electromagnetic interference when you connect with our shielded Cat5e patch cable. Constructed from high quality cable and plugs, this design minimises Near-End Crosstalk (NEXT) levels. The moulded boot provides extra strain relief and durability. Available in a variety of colours to easily colour-code your network installation.
Product Description | C2G Cat5e Booted Shielded (STP) Network Patch Cable - patch cable - 100 m - blue | Type | Patch cable - CAT 5e | Technology | Shielded twisted pair (STP) | Wiring Scheme | T568B | Wires per Cable | 8 wires | Features | Molded, minimised Near-End Crosstalk (NEXT) | Length | 100 m | Connector | RJ-45 - male | Connector (Second End) | RJ-45 - male | Colour | Blue | Manufacturer Warranty | Limited lifetime warranty |
General | |
Network Cable Type | Patch cable - CAT 5e |
Jacket Material | PVC |
American Wire Gauge (AWG) | 24 |
Pairs per Cable | 4 pairs |
Plated Connector | Gold |
Length | 100 m |
Colour | Blue |
Connectivity | |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
