Buffalo's TeraStation 5600DWR series delivers advanced 6-bay NAS and comes fully populated with high-reliability drives: perfect for production environments, medium, large, and growing businesses and demanding users. The TS5600DWR performs exceptionally during file transfers and everyday NAS functions thanks to its powerful processor, fast memory, and multiple USB ports - including USB 2.0 and USB 3.0. The TS5600DWR also includes business-critical applications such as IP camera recording, remote access, support for iSCSI target, and numerous levels of RAID for customizable capacity and redundancy depending on your specific needs. The TS5600DWR is packed with backup features such as failover, replication, scheduled backups, and a special Buffalo Media Cartridge feature that works like a tape media backup. Managing data, backups, and data sharing is made easy with Buffalo's TS5600DWR.
Product Description | BUFFALO TeraStation 5600 DWR - NAS server - 12 TB | Device Type | NAS server | Bundled Services | 3 years 24-hour TeraStation VIP HDD Exchange Service | Host Connectivity | Gigabit Ethernet | Total Storage Capacity | 12 TB | Max Supported Capacity | 24 TB | Installed Devices / Modules Qty | 6 (installed) / 6 (max) | Dimensions (WxDxH) | 17 cm x 23 cm x 26 cm | Weight | 10 kg () | Processor | 1 x Intel Atom D2700 2.13 GHz (Dual-Core) | Storage Controller | RAID SATA 3Gb/s RAID RAID 0, 1, 5, 6, 10, 50, JBOD, 51 | Hard Drive | 6 x 2 TB SATA 3Gb/s | Networking | 10Mb LAN, 100Mb LAN, GigE | RAM | 2 GB | Power | AC 120/230 V (50/60 Hz) | Storage Operating System | Linux | System Requirements | Microsoft Windows 2000 Server, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Windows 8, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1, Apple MacOS X 10.4 - 10.9, Windows 10 | Manufacturer Warranty | 3-year warranty |
General | |
Width | 17 cm |
Depth | 23 cm |
Height | 26 cm |
Weight | 10 kg () |
Built-in Devices | Status LCD |
Processor / Memory | |
Processors Installed | 1 x Intel Atom D2700 2.13 GHz |
Number of Cores | Dual-Core |
Max Supported Qty | 1 |
RAM | 2 GB DDR3 |
Storage Controller | |
Type | RAID |
Interface Type | SATA 3Gb/s |
RAID Level | RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, JBOD, RAID 51 |
Hard Drive | |
Type | HDD - hot-swap |
Capacity | 6 x 2 TB |
Networking | |
Data Link Protocol | 10Mb LAN, 100Mb LAN, GigE |
Network / Transport Protocol | TCP/IP, UDP/IP |
Remote Management Protocol | SNMP, HTTP, HTTPS |
Network Services Compatibility | Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, SFTP |
Features | LDAP support, wake on LAN (WOL), DFS support, FTP server, Buffalo Web Access, BitTorrent Client, DLNA Media Server, Apple Time Machine compatible, NTP time synchronisation, SFTP server |
Compliant Standards | DLNA CERTIFIED |
Expansion / Connectivity | |
Expansion Bays | 6 (total) / 0 (free) x hot-swap |
Interfaces | 2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 3 x USB 3.0 - Type A , 1 x serial - DB-9 |
Miscellaneous | |
Features | Device-to-device data replication, Citrix Ready, VMware Ready |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 120 Watt |
Software / System Requirements | |
Software Included | NovaBACKUP Business Essentials (10 licences), SoleraTec Phoenix RSM (1 license), Buffalo Surveillance Server |
OS Required | Microsoft Windows 2000 Server, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Windows 8, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1, Apple MacOS X 10.4 - 10.9, Windows 10 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
