DriveStation Velocity is the perfect solution for those who need to transfer files quickly and easily. The amazing speed performance comes from a combination of a more efficient improved USB 3.0 interface, Buffalo's enhanced TurboPC EX data transfer and copy utility and a 7,200 rpm drive. If you haven't moved up to USB 3.0 yet - DriveStation Velocity is backward compatible with USB 2.0.
The unit is also optimal for users who want to restrict access to their personal drive when on a shared computer or network. Powerful yet easy-to-use security options include automatic hardware encryption that protects your data, with no loss of performance.
Product Description | BUFFALO DriveStation Velocity - hard drive - 6 TB - USB 3.0 | Type | Hard drive - external (desktop) | Capacity | 6 TB | Hardware Encryption | Yes | Interface | USB 3.0 | Data Transfer Rate | 5.0 Gbps (USB 3.0) | Spindle Speed | 7200 rpm | Features | Hardware Full Disk Encryption (FDE), automatic backup, ECO, cooling fan, power management support, 256-bit AES | Dimensions (WxDxH) | 3.9 cm x 18.9 cm x 12.3 cm | Weight | 950 g | Localisation | Europe | Manufacturer Warranty | 2-year warranty |
General | |
Device Type | Hard drive - external (desktop) |
Capacity | 6 TB |
Width | 3.9 cm |
Depth | 18.9 cm |
Height | 12.3 cm |
Weight | 950 g |
Performance | |
Interface Transfer Rate | 5.0 Gbps (USB 3.0) |
Expansion & Connectivity | |
Interfaces | 1 x USB 3.0 - 9 pin USB Type B |
Power | |
Power Device | Power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption | 18 Watt (active) , 150 mW (standby) |
Software & System Requirements | |
Software Included | Buffalo Tools |
OS Required | Microsoft Windows XP, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.7 or later, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits) |
Miscellaneous | |
Compliant Standards | Plug and Play |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
