Buffalo's TeraStation Duo is the ideal choice for businesses or demanding users looking to implement a cost effective RAID based Network Attached Storage solution. As the TeraStation III's little cousin, the TeraStation Duo is a dual drive unit that includes all firmware features presently found in the Buffalo lineup of NAS products. In contrast to the TeraStation III 4-drive product, the TeraStation Duo supports RAID 0 and RAID 1 in addition to a simple JBOD configuration. Especially, business oriented features, such Active Directory support, DFS support, disk quota support, a share level replication feature and port trunking make the TeraStation Duo a top choice for small to medium sized businesses. Hardware features like hot swap and dual Ethernet ports add to the list of new features. Reliability and performance are again the key design criteria for the TeraStaion Duo. A heavy-duty power supply and oversized cooling system, as well as vastly improved CPU speed guarantee excellent and reliable performance. It is the clear choice for those users who desire reliability and robust features at an affordable price.
Product Description | BUFFALO TeraStation Duo TS-WX2.0TL/R1 - NAS server - 2 TB | Device Type | NAS server | Host Connectivity | Gigabit Ethernet | Total Storage Capacity | 2 TB | Installed Devices / Modules Qty | 2 (installed) / 2 (max) | Dimensions (WxDxH) | 17 cm x 17 cm x 23 cm | Weight | 4.5 kg () | Storage Controller | RAID SATA 3Gb/s RAID 0, 1, JBOD | Hard Drive | 2 x 1 TB SATA 3Gb/s | Networking | Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE | Power | AC 230V (50/60 Hz) | System Requirements | Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Apple MacOS X 10.5 or later, Microsoft Windows Server 2008, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits) | Manufacturer Warranty | 3-year warranty |
General | |
Width | 17 cm |
Depth | 17 cm |
Height | 23 cm |
Built-in Devices | Status LCD, print server |
Storage Controller | |
Type | RAID - internal |
Interface Type | SATA 3Gb/s |
Supported Devices | Hard drive, disk array (RAID) |
RAID Level | RAID 0, RAID 1, JBOD |
Hard Drive | |
Type | HDD - hot-swap |
Capacity | 2 x 1 TB |
Spindle Speed | 7200 rpm |
Networking | |
Type | Network adapter - integrated |
Data Link Protocol | 10Mb LAN, 100Mb LAN, GigE |
Network / Transport Protocol | TCP/IP, NTP, FTP, SMB |
Remote Management Protocol | HTTP |
Features | 128-bit encryption, BitTorrent Client |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, DLNA CERTIFIED |
Expansion / Connectivity | |
Expansion Bays | 2 (total) / 0 (free) x internal |
Interfaces | 2 x USB 2.0 - Type A , 2 x Ethernet 1000Base-T - RJ-45 , 1 x serial RS-232 |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 230V (50/60 Hz) |
Power Consumption Operational | 47 Watt |
Software / System Requirements | |
Software Included | NovaBACKUP Business Essentials |
OS Required | Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Apple MacOS X 10.5 or later, Microsoft Windows Server 2008, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% |
The following resources are available for the Buffalo 2TB Terastation Duo NAS
