Storage solution that fits snugly into your palm: Buffalo LinkStation™ Mini is the perfect network storage for users on the go.
The first Network Attached Storage product in the world using 2.5" hard disks! The Auto Power on / off function enables the LinkStation to turn off automatically when you shut down the last PC or laptop with installed NAS Navigator software. So small and compact that it fits perfectly in the palm of your hand, with features such as 60% lower power consumption, fanless operation and low noise make the LinkStation Mini the ideal storage solution for anywhere in your home.
Product Description | BUFFALO LinkStation Mini - NAS server - 1 TB | Device Type | NAS server | Host Connectivity | Gigabit Ethernet | Total Storage Capacity | 1 TB | Installed Devices / Modules Qty | 2 (installed) / 2 (max) | Dimensions (WxDxH) | 8.2 cm x 4 cm x 13.5 cm | Weight | 0.5 kg () | Storage Controller | RAID SATA 1.5Gb/s RAID 0, 1 | Hard Drive | 2 x 500 GB SATA 1.5Gb/s | Networking | Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE | Power | AC 120/230 V (50/60 Hz) | System Requirements | Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows Vista, Microsoft Windows Server 2008 | Manufacturer Warranty | 2-year warranty |
General | |
Width | 8.2 cm |
Depth | 4 cm |
Height | 13.5 cm |
Enclosure Colour | Black |
Built-in Devices | Print server |
Storage Controller | |
Type | RAID - internal |
Interface Type | SATA 1.5Gb/s |
Supported Devices | Hard drive, disk array (RAID) |
RAID Level | RAID 0, RAID 1 |
Hard Drive | |
Type | HDD |
Capacity | 2 x 500 GB |
Spindle Speed | 5400 rpm |
Networking | |
Type | Network adapter - integrated |
Data Link Protocol | 10Mb LAN, 100Mb LAN, GigE |
Network / Transport Protocol | TCP/IP, AppleTalk, SMB |
Remote Management Protocol | HTTP, HTTPS |
Network Services Compatibility | Microsoft Active Directory (AD), Apple Bonjour Protocol, Server Message Block (SMB) |
Features | LDAP support, Buffalo Web Access, BitTorrent Client |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, DLNA CERTIFIED |
Expansion / Connectivity | |
Expansion Bays | 2 (total) / 0 (free) x internal |
Interfaces | 1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A |
Miscellaneous | |
Compliant Standards | RoHS |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 17 Watt () |
Software / System Requirements | |
Software Included | NovaBACKUP Workstation - Buffalo Edition (5 licences) |
OS Required | Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows Vista, Microsoft Windows Server 2008 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
