Payday Tech Sale: The Biggest Brands. The Biggest Savings. Treat yourself to some new tech.
BT Shop Power Bank Portable 2200mAh Charger
3 on order, delivery delayed
Product codes
chevron icon
chevron icon
Charge your smart phone or tablet with this 2200mAh power bank when you are on the go. Engraved with the BT logo and styled with metal trim to both ends. Will charge any phone which uses a USB charging lead. Supplied with a charging cable which is compatible with any USB port.
Please note, the supplied cable is only for charging the powerbank unit; to charge your phone or tablet you will need to use the devices specific charging cable, simply connect the cable to your device and plug the other end into the powerbank the same way you would a USB mains plug.
  • Measures L 9.5cm x W 2cm x D 2cm
  • Weight 81g
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
