Works with any Broadband provider
BT's Dual-Band Wi-Fi Extender 610 Kit has been designed to work with any service provider to make sure everyone can make the most of their broadband around their home.
What does BT's Dual-Band Wi-Fi Extender 610 give you?
Extend the range of your Wi-Fi around your home and enjoy the full broadband experience. **Easy set-up - No install necessary, just connect to your router and access the internet in minutes!**
Everyone loves to be online; and why should you settle for anything other than the complete broadband experience? With BT's Dual-Band Wi-Fi Extender 610, you are able to extend the range of you wireless broadband and connect all your wireless devices wherever and whenever you like.
Ideal for HD/3D streaming, online gaming or faster downloads; BT's Dual-Band Wi-Fi Extender 600 supports all your online needs.
Simple to use
The Dual-Band Wi-Fi Extender 610 from BT is easy to use. Simply plug into your wall socket and link with your router and you are ready to enjoy an extended wireless broadband experience.
Increase your Wi-Fi range
BT's Dual-Band Wi-Fi Extender 610 allows you to extend the range of your wireless broadband, meaning dead-spots are a thing of the past.
What is Dual-Band wireless technology?
Dual-Band wireless technology is a second, different, wi-fi signal that your devices will connect to automatically if compatible. If not, use the BT Dual-Band Wi-Fi Dongle 600 to take advantage of the improved speed and reliability on offer.
The BT connectivity range
BT's Dual-Band Wi-Fi Extender 610 is just one part of BT's new connectivity range, which has been designed to solve all connectivity issues to ensure everyone makes the most of their broadband around their home. Other products include Broadband Extenders, Dongles, Dual-Band upgrade kits and switches, ensuring all your major connectivity requirements are covered.
Box Contains
Manufacturer Warranty | 3 Years Warranty |
