BT Baby Monitor 200
A great baby monitor can make a real difference. It'll help make life easier for you, and give you complete reassurance by keeping you close to your baby, even when you're away.
One of the best buys you can make for you and your baby is a baby monitor. The best monitors have grown up and adopted all sorts of new technology, so you'll be amazed by what they can do.
Colour | White/Purple | Sound level indicator | Yes | Power on/off | Yes | Nightlight | Yes | Sensitivity Control | Yes | Battery Type (parent) | NiMH | Belt Clip | No | Volume Control | Yes | Battery Size (parent) | AA | Wall Mount | No | Mute | Yes | Battery Capacity (parent) | 1300mAh | Clock | No | Vibrating Alert | No | Timer | No | Temperature Alert | No | Battery Type (baby) | Alkaline | Out of range alert | Yes | Paging | Yes | Battery Size (baby) | n/a | Talk Back | Yes | Baby Unit (Weight) | 134g | Parent Unit (Weight) | 92g | Charger (Weight) | 41g | Baby Unit (Dimensions) | 5.7 x 11 x 11.9 cm | Parent Unit (Dimensions) | 4.5 x 6.6 x 9.4 cm | Charger (Dimensions) | 3.8 x 8.6 x 6.9 cm | Country of manufacture | China |
The following resources are available for the BT Baby Monitor 200
