3TB Intenso Desktop Memory Center USB 3.0 Hard Drive
Capacity - 1TB/2TB/3TB
Form Factor - 3.5" (8.89 cm)
Maximum data transfer rate - Reading: 85,00 MB/s (570 x) / Writing: 75,00 MB/s (503 x) - RPM/Cache - 5400 U/min. -32MB
File format - FAT 32
Product Description | Intenso Memory Center - hard drive - 3 TB - USB 3.0 | Type | Hard drive - external (desktop) | Capacity | 3 TB | Form Factor | 3.5" | Interface | USB 3.0 | Data Transfer Rate | 5.0 Gbps (USB 3.0) | Buffer Size | 32 MB | Spindle Speed | 5400 rpm | Power Source | Included AC adapter | Enclosure Colour | Black | Dimensions (WxDxH) | 12.1 cm x 19 cm x 3.5 cm | Weight | 0.95 kg |
General | |
Device Type | Hard drive - external (desktop) |
Capacity | 3 TB |
Width | 12.1 cm |
Depth | 19 cm |
Height | 3.5 cm |
Weight | 0.95 kg |
Performance | |
Interface Transfer Rate | 5.0 Gbps (USB 3.0) |
Max Data Transfer Rate | 85 MB/s |
Data Transfer Rate Details | USB 3.0 (read): 85 MB/s , USB 3.0 (write): 75 MB/s |
Expansion & Connectivity | |
Interfaces | 1 x USB 3.0 |
Compatible Bay | 3.5" |
Power | |
Power Device | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Software & System Requirements | |
OS Required | Apple MacOS X 10.x, Microsoft Windows Vista / XP / 7 |
Miscellaneous | |
Cables Included | 1 x USB 3.0 cable - USB Type A to B - external |
Compliant Standards | WEEE |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 55 °C |
Humidity Range Operating | 8 - 90% |
