BT.com
Wishlist
BenQ GL2250HM 21.5" 1920x1080 5ms VG HDMI LED Monitor
BenQ GL2250HM 21.5" 1920x1080 5ms...
£99.98
38 in stock
£99.98
Add to wishlist
Delivery
Standard 1-3 working days
Whether you're catching up on the latest show on the Internet or viewing documents, the BenQ GL2250HM LED monitor is the perfect choice for you in style! Featuring a dynamic ratio of 12M:1, speakers, response time of 2ms and DVI and HDMI connector, this 21.5"W 16:9 LED monitor delivers you the audiovisual enjoyment.
BenQ GL2250HM - LED monitor - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class B
Energy Consumption per Year
36 kWh
Power Consumption (On mode)
25 W
Stereo speakers
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
5 ms (typical); 2 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Glossy black
52.469 cm x 17.39 cm x 39.99 cm
3.8 kg
Environmental Standards
ENERGY STAR Qualified
TCO Displays 5.0
Display Type
Energy Class
Class B
36 kWh
25 W
Diagonal Size
21.5"
Built-in Devices
Stereo speakers
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
HDCP, Advanced Motion Accelerator (AMA) technology, 72% NTSC colour gamut, Senseye Human Vision Technology, Senseye 3 Technology, Flicker Free technology
Glossy black
52.469 cm x 17.39 cm x 39.99 cm - with stand
3.8 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
VGA , DVI-D , HDMI , Audio line-in (mini-jack) , Headphone input (mini-jack)
Mechanical
Tilt
Tilt Angle
-5/+15
Flat Panel Mount Interface
100 x 100 mm
K-lock security slot
TCO Displays 5.0
30 Watt
Power Consumption Stand by
0.3 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 52.469 cm - depth: 17.39 cm - height: 39.99 cm - weight: 3.8 kg , Without stand - width: 52.469 cm - depth: 6.05 cm - height: 31.979 cm
Scroll to top
