BT.com
Wishlist
BenQ BL2711U 27" 3840x2160 4ms DVI HDMI USB 4K LED Monitor
BenQ BL2711U 27" 3840x2160 4ms DVI...
£469.29
10 in stock
£469.29
Add to wishlist
Delivery
Standard 1-3 working days
Designed to meet the rising demands for large-sized viewing and ultra-high definition, the BL2711U boasts a 27"W 4K2K display built with BenQ's advanced IPS technology, providing professionals in CAD/CAM, animation, video editing and graphic arts ultra-precise color rendition and over 300% working space to enhance their work efficiency and productivity.
BenQ BL series BL2711U - LED monitor - 4K - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
82 kWh
Power Consumption (On mode)
56 W
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
4K 3840 x 2160
Pixel Pitch
0.155 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
2xHDMI, DVI-D, DisplayPort
Speakers
Integrated
Display Position Adjustments
Pivot (rotation), tilt
Black, matte
63.9 cm x 24 cm x 55.1 cm
Environmental Standards
ENERGY STAR Qualified
TUV GS, EN 60950, TUV Ergo, TCO Displays 6.0, ISO9241-307
3 years warranty
Display Type
Energy Class
Class C
82 kWh
56 W
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
4K 3840 x 2160
Pixel Pitch
0.155 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, sharpness, colour balance, colour temperature
HDCP, Senseye 3 Technology, Eco Light Sensor, Low Blue Light Mode, Flicker Free technology, CAD/CAM Mode, Auto Pivot, OSD controller
Black, matte
63.9 cm x 24 cm x 55.1 cm - with stand
Audio
Speakers - stereo - integrated
Output Power / Channel
3 Watt
DVI-D (dual link) , DisplayPort , 2 x HDMI , 2 x USB 2.0 , 2 x USB 3.0 , Headphones , Audio line-in
Mechanical
Tilt Angle
-5/+20
Height Adjustment
140 mm
Flat Panel Mount Interface
100 x 100 mm
1 x network cable , 1 x HDMI cable , 1 x DVI cable , 1 x VGA cable , 1 x DisplayPort cable , 1 x audio cable , 1 x USB cable
Power Supply
Internal
AC 90 - 264 V (47 - 63 Hz)
42 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Included Software
Drivers & Utilities
Dimensions & Weight Details
Without stand - width: 63.9 cm - depth: 7 cm - height: 38.5 cm
ENERGY STAR Certified
Limited warranty - 3 years - on-site
5 °C
20 - 90%
Accessories
£9.99
£5.41
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£15.68
£39.78
£53.88
£17.48
Scroll to top
