Charge your smartphone and tablet at home or on the go with the BOOST?UP 2-port swivel charger + outlet. This compact charger includes two universal USB ports, offering convenient one-stop charging for your mobile devices. In addition to the two USB ports, the charger also has an AC outlet, so you can plug in your computer or other appliance while powering your mobile devices. And with 12 watts of combined power, your devices will charge quickly.
This charger swivels 360 degrees, making it easy to fit in tight spaces. This means the charger rotates up and out of the way so it won't block other outlets.
Product Description | Belkin BOOST UP 2-Port Swivel Charger + Outlet power adapter - BS 1363, 2 x USB - 12 Watt | Product Type | Power adapter | Output Connector Type | Total 3: BS 1363, 2 x USB | Max Electric Current | 2.4 A | Power Provided | 12 Watt | Power Device Details | 2 x - 4 pin USB Type A - 2.4 A , - power BS 1363 |
General | |
Designed For | Portable player, tablet, mobile phone |
Power Device | |
Input Connectors | Power BS 1363 |
Output connectors | Total 3: power BS 1363, 2 x 4 pin USB Type A |
Power Device Details | 2 x 4 pin USB Type A - 2.4 A , Power BS 1363 |
Features | 360° rotation |
Miscellaneous | |
Equipment Protection Value | 1500 British Pounds |
