Belkin CAT5e Networking Cables allow you to connect your IT hardware to the network, providing reliable performance.
Product Description | Belkin patch cable - 10 m - grey | Type | Patch cable - CAT 5e | Technology | Unshielded twisted pair (UTP) | Features | Molded, snagless | Length | 10 m | Connector | RJ-45 - male | Connector (Second End) | RJ-45 - male | Colour | Grey | Manufacturer Warranty | Limited lifetime warranty | Designed For | Omniview SMB 1x16 KVM-over-IP Switch, SMB 1x8 KVM-over-IP Switch; OmniView SMB CAT5 KVM Switch |
General | |
Network Cable Type | Patch cable - CAT 5e |
Plated Connector | Gold |
Length | 10 m |
Colour | Grey |
Connectivity | |
Miscellaneous | |
Compliant Standards | Up to 100 MHz |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
Designed For | Belkin Omniview SMB 1x16 KVM-over-IP Switch, SMB 1x8 KVM-over-IP Switch , Belkin OmniView SMB CAT5 KVM Switch |
