ITEM | QTY | PRICE |
Logitech M90 Wired Scroll Mouse
4 | £23.92 |
Feel every emotion with Beats Studio Pro’s immersive listening experience. A fully custom acoustic platform provides powerful, balanced sound. Personalised Spatial Audio with dynamic head tracking delivers a 360 audio experience (1). When you want to silence distractions, Active Noise Cancelling adapts in real-time to neutralise the world around you. And when you want a more natural experience, Transparency mode seamlessly mixes the world outside with what you’re listening to. With up to 40 hours of battery life (2), enhanced Apple and Android compatibility (3), and flexible connectivity, every aspect of these headphones has been reimagined to keep you connected to the emotion behind the music for longer.
(1) Compatible hardware and software required. Works with compatible content in supported apps. Not all content available in Dolby Atmos. iPhone with TrueDepth camera required to create a personal profile for Spatial Audio, which will sync across Apple devices running the latest operating system software, including iOS, iPadOS, macOS and tvOS.
(2) Testing conducted by Apple in May 2023 using pre-production Beats Studio Pro units and software paired with iPhone 13 units and pre-release software. The playlist consisted of 358 unique audio tracks purchased from the iTunes Store (256 Kbps AAC encoding). Volume was set to 50% and Active Noise Cancelling and Transparency were turned off. Testing consisted of full Beats Studio Pro battery discharge while playing audio until Beats Studio Pro stopped playback. With Active Noise Cancellation turned on, listening time was up to 24 hours. Battery life depends on device settings, environment, usage and many other factors.
(3) Requires an iCloud account and a compatible Apple device running the latest operating system software or a compatible Android device running Android 8.0 or later, with Google Play Services enabled.
Customer return - item has been used but is in excellent condition
Ref: HCXC 048594 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
£181.90
