TAP. PAIR. PLAY.
Pairing is easy. Just tap your phone to your Beats Pill and create an instant connection. Sync two Beats Pills by tapping them together to play the same song. You can also tap the Beats Pills together twice to stereo your music, making one Beats Pill the left output and the other the right.
SMALL SIZE, BIG SOUND.
Despite its compact size, the Beats Pill produces powerful sound. It’s easy to enjoy soaring highs and deep, booming bass in every room of the house.
CHANGE TRACKS FROM YOUR PHONE
Pair the Beats Pill to your phone, laptop or any other Bluetooth-enabled device to change tracks and adjust the volume from up to 30 feet away.
TOTALLY PORTABLE
The Beats Pill frees you to roam so you'll always have premium sound, anywhere you go. It’s lightweight and small enough to fit in your bag. If your phone or external device is low on battery power, you can use the Beats Pill to give it some juice.
BLUETOOTH CONFERENCING
Take that call. The Beats Pill’s Bluetooth capability and internal microphone make talking on the phone easier and better sounding than ever before.
UNBOXED
Beats Pill™ Portable Stereo Speaker with Bluetooth 1.5 m audio cable (3.5mm to 3.5 mm) USB 2.0 charge/data cable Carry case AC Power Adapter
Weight (kg): 0.31 Height (mm): 45.72 Length (mm): 190.50
Product Description | Beats by Dr. Dre Pill 2.0 - speaker - for portable use - wireless | Product Type | Speaker - for portable use | Speaker Type | Active | Amplifier | Integrated | Interfaces | Bluetooth, NFC | Speaker Details | Speaker - stereo x 2 - active | Colour | Black | Power Options | USB charging | Battery | Speaker battery rechargeable - Lithium Ion | Dimensions (WxDxH) | 19 cm 4.5 cm | Weight | 310 g |
General | |
Hands-Free Function | Yes |
Enclosure Colour | Black |
Speaker System | |
Interfaces | Bluetooth, Near Field Communication (NFC) |
Transmission Range | 10 m |
Controls | Power on/off, volume, call answer, play/pause, next track, previous track |
Additional Features | Daisy-chain capability |
Speaker System Details | |
Connections | |
Connector Type | Audio line-in (mini-phone stereo 3.5 mm) , Audio line-out (mini-phone stereo 3.5 mm) , DC power output (4 PIN USB Type A) |
Miscellaneous | |
Included Accessories | Carrying case, AC power adaptor, audio cable, USB cable |
Power | |
Power Source | Battery |
Battery | |
Type | Rechargeable - Lithium Ion |
Run Time (Up To) | 7 hour(s) |
Dimensions & Weight | |
Width | 19 cm |
Height | 4.5 cm |
Weight | 310 g |
