Beats Pill+ is designed to go wherever you do and fill the room with a rich clear sound field that has as much power as it does definition. With a sleek interface, the Beats Pill+ is intuitive to use and brings people together with engaging features for a unique shared listening experience.
All Day. Every Day.
The Beats Pill+ speaker has up to 12 hours of battery life to stay charged on the go. Get a quick charge in 3 hours with the Lightning cable and even charge your phone or external music device with extra power from your Beats Pill+. The LED fuel gauge lets you know how much battery is left.
Designed Around You.
The no-nonsense interface gets you to your music fast. Play, pause, skip tracks, and control your phone calls with a touch of the multifunction "b" button. The enhanced speaker phone lets you make and receive calls with clarity.
Sound Bigger Than Its Size
The stereo active 2-way crossover system creates an optimized sound field for dynamic range and clarity across all genres of music. Tweeter and woofer separation uses the same acoustic mechanics found in professional recording studios around the world.
Beats Pill+ App
Download the Beats Pill+ app* to unlock features that put you and your friends at the center of your music like never before. Bring a second speaker into the mix for even fuller sound or sound in stereo. *Available only on the iPhone 5s or later, iPad Pro, iPad Air (all models), iPad mini 2 or later, and select Android devices.
DJ The Playlist
Grab a friend and control the music from two Bluetooth® sources.
Amplify Your Sound
Add a second Beats Pill+ into the mix and simultaneously play from both speakers for a sound that's twice as full.
Put It In Stereo
Sync two Beats Pill+ speakers together for dedicated left and right playback and an even more dynamic sound experience.
What's in the box?
Product Description | Beats Pill+ - speaker - for portable use - wireless | Product Type | Speaker - for portable use | Speaker Type | 2-way - active | Amplifier | Integrated | Interfaces | Bluetooth | Speaker Details | Speaker - stereo x 2 - 2-way - active | Colour | White | Power Options | USB charging | Battery | Speaker battery rechargeable - Lithium Ion | Dimensions (WxDxH) | 6.92 cm x 21 cm x 6.36 cm | Weight | 745 g | Manufacturer Warranty | 1-year warranty |
General | |
Hands-Free Function | Yes |
Microphone | Yes |
Enclosure Colour | White |
Speaker System | |
Controls | Power on/off, volume, call answer, play/pause, next track, previous track |
Speaker System Details | |
Driver Details | Speaker: 2 x woofer driver |
Driver Details (2nd speaker) | Speaker: 2 x tweeter driver |
Connections | |
Connector Type | Audio line-in (mini-phone stereo 3.5 mm) , DC power output (4 pin USB Type A (power only)) , DC power input (Lightning) |
Miscellaneous | |
Included Accessories | Carrying case, AC power adaptor, Lightning to USB cable |
Power | |
Power Source | Battery |
Battery | |
Type | Rechargeable - Lithium Ion |
Run Time (Up To) | 12 hour(s) |
Dimensions & Weight | |
Width | 6.92 cm |
Depth | 21 cm |
Height | 6.36 cm |
Weight | 745 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
