ASUS VZ27AQ has a space-saving design with an ultra-slim profile. Its frameless design makes it perfect for almost-seamless multi-display setups that give you an even greater degree of immersion. An advanced high-performance IPS panel gives you an astonishing 80,000,000:1 contrast ratio and wide 178° viewing angles. In addition, ASUS Eye Care technology ensures a comfortable viewing experience.
Product Description | ASUS VZ27AQ - LED monitor - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class A | Energy Consumption per Year | 35 kWh | Power Consumption (On mode) | 24 W | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | WQHD 2560 x 1440 | Pixel Pitch | 0.233 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 80000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey) | Colour Support | 1.074 billion colours (10-bit) | Colour Gamut | 100% sRGB | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Colour | Black, icicle gold | Dimensions (WxDxH) - with stand | 61.27 cm x 21 cm x 44.08 cm | Weight | 4.26 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | UL, VCCI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, KCC, WEEE, J-MOSS, ErP Ready, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Panel Type | IPS |
Vertical Refresh Rate | 49 - 76 Hz |
Horizontal Refresh Rate | 29 - 130 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Features | Ultra Slim Design, HDCP, frameless, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS GamePlus, Low Blue Light Mode, Flicker Free technology, ASUS EyeCare Technology, Blue Light Filter technology, Adaptive-Sync technology, Colour Temperature Selection |
Dimensions (WxDxH) | 61.27 cm x 21 cm x 44.08 cm - with stand |
Weight | 4.26 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 1.5 Watt |
Connectivity | |
Interfaces | VGA , HDMI , DisplayPort , Audio line-in |
Mechanical | |
Tilt Angle | -5/+22 |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable , 1 x audio cable |
Power | |
Power Consumption (Off Mode) | 0.5 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 61.27 cm - depth: 3.655 cm - height: 36.82 cm , With stand - width: 61.27 cm - depth: 21 cm - height: 44.08 cm - weight: 4.26 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 68.9 cm |
Shipping Depth | 11.7 cm |
Shipping Height | 54.4 cm |
Shipping Weight | 5.295 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
