ASUS VivoMini VM65N is a 2-liter mini PC that features the latest Intel'Skylake' processor architecture to deliver maximum performance while taking up as little space as possible. It is powered by a choice of 6th-generation Intel Core processors, and features discrete NVIDIA GeForce graphics for smooth 4K UHD visuals and casual gaming. In addition, SonicMaster audio and DDR4 RAM make it a wise choice for a daily computing platform or entertainment hub. Its compact design even houses Vivo DualBay to give you flexible storage options - you can choose between 2.5-inch SSDs or HDDs so you can speed up your operating system or have space for your movie and music libraries. It delivers superfast connectivity too, thanks to SuperSpeed USB 3.1 and 802.11ac Wi-Fi. VivoMini VM65N features a Zen-inspired spun-metal finish and an elegant Iron Gray color scheme. This stylish and well-crafted mini PC is a wonderful addition to any room of your home.
VivoMini VM65N comes with built-in SonicMaster speakers right out of the box so there's no need for external speakers. ASUS SonicMaster technology, tuned by the renowned ASUS Golden Ear team, gives you deep rich bass and crystal-clear vocals - all from a mini PC.
VivoMini VM65N features Vivo DualBay, a unique dual-storage design that can accommodate up to two 2.5-inch solid-state (SSD) or hard disk drives (HDD), or a single 3.5-inch HDD for added storage flexibility. So whether you're after larger storage capacities or faster data access speeds, you can mix and match between SSD or HDD options to better suit your needs. If you're looking for space to house your movie or music libraries, use a single 3.5-inch or two 2.5-inch HDDs. Alternatively, you can choose a combination of 2.5-inch HDD and SSD for faster data access to speed up your operating system.
Product Description | ASUS VivoMini VM65N - mini PC - Core i5 7200U 2.5 GHz - 8 GB - SSD 128 GB, HDD 1 TB | Type | Personal computer - mini PC | Processor | Intel Core i5 (7th Gen) 7200U / 2.5 GHz (, up to 3.1 GHz, (Dual-Core) | Processor Main Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache | Cache Memory | 3 MB | Cache Per Processor | 3 MB | RAM | 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000 | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | SSD 128 GB - SATA 6Gb/s - 2.5" | Hard Drive (2nd) | HDD 1 TB - SATA 6Gb/s | Optical Storage | No optical drive | Card Reader | 4 in 1 | Multi-GPU Configuration | 1 single GPU card / integrated GPU | Graphics Controller | NVIDIA GeForce 930M / Intel HD Graphics 620 | Audio Output | Stereo | Networking | 1GbE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5 | OS Provided | Windows 10 Home | Colour | Iron grey | Dimensions (WxDxH) | 19 cm x 19 cm x 5.62 cm | Weight | 1.2 kg | Environmental Standards | ENERGY STAR Qualified |
General | |
Type | Personal computer |
Product Form Factor | Mini PC |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7200U |
Clock Speed | 2.5 GHz |
Max Turbo Speed | 3.1 GHz |
Number of Cores | Dual-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
Cache Memory | |
Installed Size | 3 MB |
RAM | |
Installed Size | 8 GB / 32 GB (max) |
Technology | DDR4 SDRAM - non-ECC |
Effective Memory Speed | 2133 MHz |
Rated Memory Speed | 2133 MHz |
Memory Specification Compliance | PC4-17000 |
Form Factor | SO-DIMM 260-pin |
Slots | 2 (Total) |
Features | Unbuffered, dual channel memory architecture |
Hard Drive | |
Type | SSD - 2.5" |
Capacity | 1 x 128 GB |
Interface Type | SATA 6Gb/s |
Hard Drive (2nd) | |
Type | HDD |
Interface Class | Serial ATA |
Capacity | 1 x 1 TB |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Optical Storage | |
Type | No optical drive |
Card Reader | |
Type | 4 in 1 card reader |
Supported Flash Memory Cards | MultiMediaCard, SD Memory Card, SDHC Memory Card, SDXC Memory Card |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | NVIDIA GeForce 930M / Intel HD Graphics 620 |
Video Interfaces | HDMI, DisplayPort |
Audio Output | |
Sound Output Mode | Stereo |
Speakers Included | 2 x right / left channel |
Networking | |
Wireless LAN Supported | Yes |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac |
Compliant Standards | Wi-Fi CERTIFIED |
Expansion / Connectivity | |
Bays | 2 (total) / 0 (free) x internal 2.5" x 1/8H |
Slots | 1 (total) / 0 (free) x CPU , 2 SO-DIMM 260-pin |
Interfaces | 4 x USB 3.0 , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort , 1 x headphones - mini-jack , 2 x USB 3.1 , 1 x TOSLINK output , 1 x microphone - mini-jack |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
VESA Mounting Interface | Yes |
Compliant Standards | UL, VCCI, BSMI, CCC, FCC |
Power | |
Device Type | Power adapter |
Power Provided | 90 Watt |
Operating System / Software | |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Dimensions & Weight | |
Width | 19 cm |
Depth | 19 cm |
Height | 5.62 cm |
Weight | 1.2 kg |
