Leaving a laptop plugged in when the battery is already fully charged may degrade the battery, resulting in a shorter lifespan. It may also lead to battery swelling due to internal gas buildup caused by oxidation, potentially warping or damaging the laptop. ASUS Battery Health Charging technology allows you to set the state of charge to 60%, 80% or 100%, prolonging battery lifespan and reducing the chance of battery swelling. The ASUS VivoBook 14 features a lithium-polymer battery that has 3x the lifespan of standard lithium-ion batteries. A USB 3.1 port with a reversible USB Type-C connector makes connecting devices quick and easy. USB 3.1 provides data transfer speeds as fast as 5 Gbps - up to 10x faster than USB 2.0 connections! The ASUS VivoBook 14 also features HDMI and VGA ports, as well as a 3-in-1 SD/SDHC/SDXC card reader for hassle-free compatibility with a wide range of peripherals, displays and projectors.
Product Description | ASUS 14 X442UA-GA061R - 14" - Intel Core i5 - 7200U - 4 GB RAM - 1 TB HDD | Product Type | Notebook | Operating System | Win 10 Pro 64-bit | Processor | Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache | Memory | 4 GB DDR4 (provided memory is soldered) | Storage | 1 TB HDD / 5400 rpm | Optical Drive | DVD SuperMulti | Display | 14" LED backlight 1366 x 768 / HD | Graphics | Intel HD Graphics 620 | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet | Battery | 2-cell | Colour | Matte silver IMR (top), matte dark grey IMR (LCD cover) | Dimensions (WxDxH) | 34.8 cm x 24.28 cm x 2.36 cm | Weight | 1.9 kg |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7200U / 2.5 GHz |
Max Turbo Speed | 3.1 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 4 GB (provided memory is soldered) |
Max RAM Supported | 12 GB |
Technology | DDR4 SDRAM |
Speed | 2133 MHz |
Rated Speed | 2133 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 1 |
Empty Slots | 1 |
Storage | |
Main Storage | 1 TB HDD SATA / 5400 rpm |
Optical Drive | DVD±RW (±R DL) / DVD-RAM |
Display | |
Type | 14" |
LCD Backlight Technology | LED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 200 cd/m² |
Colour Gamut | 45% NTSC |
Features | Ultra Slim Design, ASUS Splendid Video Intelligence Technology, glare, ASUS EyeCare Technology, Tru2Life |
Audio & Video | |
Graphics Processor | Intel HD Graphics 620 |
Camera | Yes - VGA |
Sound | Stereo speakers, microphone |
Audio Features | Output: ASUS SonicMaster, ASUS AudioWizard |
Input | |
Type | Keyboard, touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.1 |
Network Interface | Gigabit Ethernet |
Battery | |
Technology | 2-cell Lithium Ion |
Capacity | 38 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 19 V, 2.37 A |
Connections & Expansion | |
Interfaces Details | Headphone/microphone combo jack , USB 3.0 , USB 2.0 , USB-C 3.1 Gen 1 , HDMI , LAN , VGA |
Memory Card Reader | Yes (SD Card, SDHC Card, SDXC Card) |
Miscellaneous | |
Features | System password, hard drive password, ASUS IceCool design, ASUS Battery Health charging technology |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Included Accessories | Power adapter |
Dimensions & Weight | |
Weight | 1.9 kg |
Sustainability Information | |
TCO Certified | - |
