The ultra-thin, feather-light ASUS Transformer Mini is two amazing devices in one. Built from a magnesium-aluminum alloy, it's ultra portable and has a long battery life.
Product Description | ASUS Transformer Mini T102HA GR035T - 10.1" - Intel Atom x5 - Z8350 - 4 GB RAM - 64 GB eMMC | Product Type | Tablet - with keyboard dock | Operating System | Win 10 Home 64-bit | Processor | Intel Atom x5 Z8350 / 1.44 GHz, up to 1.92 GHz / 2 MB Cache | Memory | 4 GB DDR3 (provided memory is soldered) | Storage | 64 GB eMMC | Display | 10.1" LED backlight touchscreen 1280 x 800 / WXGA | Graphics | Intel HD Graphics | Input Device | Keyboard, touchpad | Integrated Webcam | Yes | Networking | Bluetooth 4.0, 802.11a/b/g/n/ac | Battery | 2-cell - up to 11 hours | Dockable | Yes | Security | Fingerprint reader | Colour | Quartz grey | Dimensions (WxDxH) - tablet | 25.9 cm x 17 cm x 0.82 cm | Weight | 530 g | Environmental Standards | - EPEAT Climate+ | Specific Absorption Rate (SAR) | 1.578 W/kg (body) , 1.578 W/kg (limb) |
General | |
Operating System | Windows 10 Home 64-bit Edition |
Processor / Chipset | |
CPU | Intel Atom x5 Z8350 / 1.44 GHz |
Max Turbo Speed | 1.92 GHz |
Number of Cores | Quad-Core |
Cache | 2 MB |
64-bit Computing | Yes |
Memory | |
RAM | 4 GB (provided memory is soldered) |
Technology | DDR3 SDRAM |
Storage | |
Main Storage | 64 GB eMMC |
Display | |
Type | 10.1" |
LCD Backlight Technology | LED backlight |
Touchscreen | Yes (10-point multi-touch) |
Resolution | 1280 x 800 (WXGA) |
Widescreen | Yes |
Image Aspect Ratio | 16:10 |
Image Brightness | 400 cd/m² |
Colour Gamut | 60% NTSC |
Features | Ultra Slim Design, ASUS Splendid Video Intelligence Technology, WideView, ASUS TruVivid technology, ASUS EyeCare Technology |
Audio & Video | |
Graphics Processor | Intel HD Graphics |
Camera | Yes |
Resolution | 2 Megapixel |
Camera Features | Windows Hello |
Sound | Stereo speakers, microphone |
Audio Features | Output: ASUS SonicMaster, ASUS AudioWizard |
Input | |
Type | Keyboard, touchpad |
Features | ASUS Smart Gesture technology |
Communications | |
Wireless | Bluetooth 4.0, 802.11a/b/g/n/ac |
Battery | |
Technology | 2-cell lithium polymer |
Capacity | 32 Wh |
Run Time | Up to 11 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 18 Watt, 9 V, 2 A |
Connections & Expansion | |
Interfaces Details | Micro-HDMI , Headphone/microphone combo jack , USB 3.0 , Micro-USB 2.0 , Dock |
Memory Card Reader | Yes (microSD, microSDHC, microSDXC) |
Miscellaneous | |
Case Material | Plastic, metal |
Dockable | Yes |
Included Accessories | Stylus, power adapter |
Compliant Standards | UL, C-Tick, BSMI, CB, JATE, CCC, MIC, FCC, RoHS, A-Tick, GOST-R, iDA, ErP 2013 |
SAR Value | 1.578 W/kg (body), 1.578 W/kg (limb) |
Dimensions & Weight | |
Weight | 530 g |
Dimensions (WxDxH) / Weight Details | 25.9 cm x 17 cm x 1.39 cm / 790 g - tablet with keyboard , 25.9 cm x 17 cm x 0.82 cm / 530 g - tablet |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
