ASUS STRIX R9 380 delivers pumped gaming performance and extreme reliability
990 MHz engine clock for outstanding performance and gaming experience.
DirectCU II with 0dB fan technology lets you enjoy light games in complete silence, and hardcore gaming 20% cooler with 3X-quieter performance.
Auto-Extreme Technology with Super Alloy Power II delivers premium aerospace-grade quality and reliability.
GPU Tweak II with Xsplit Gamecaster provides intuitive performance tweaking and lets you stream your gamplay instantly.
Taken from the ancient Roman and Greek word for owl, Strix means the keenest hearing and sharpest eyesight. Strix means feeling your environment so that you detect and react to the slightest movement. Strix means survival on the very edge of instinct. Strix is in your blood, as it is in ours.
ASUS STRIX R9 380 gaming graphics cards packed with exclusive ASUS technologies, including DirectCU II with Dual Wing-Blade 0dB Fan Design for maximum air flow with 20% cooler and 3X quieter performance. This card features exclusive ASUS AUTO-EXTREME Technology with Super Alloy Power II for premium aerospace-grade quality and reliability. It also has GPU Tweak II with Xsplit Gamecaster, provides intuitive performance tweaking and lets you stream your gameplay instantly.
DirectCU II with 10mm Heatpipe
20% Cooler and 3X Quieter Performance
Exclusive DirectCU II cooling technology outperforms reference designs with an exclusive 10mm heatpipe that transports 40% more heat away from the GPU -- a first for the industry! The design also includes 1.5X-larger heat-dissipation: this means performance that's 20% cooler three-times (3X) quieter than reference for ultra-stable hardcore gaming with very low noise.
Dual Wing-blade 0dB Fan Design
Max Air Flow with 105% More Air Pressure
DirectCU II features dual 0dB fans engineered with a patented, new wing-blade design that delivers maximum air flow and improved 105% static pressure over the heat sink, while operating at 3X quieter volumes than reference cards. The 0dB fans also let you enjoy games like League of Legends® and StarCraft® in complete silence -- because the fan stops completely when the GPU temperature remains below a set level.
All ASUS graphics cards are now produced using AUTO-EXTREME Technology, an industry-first, 100% automated production process that incorporates premium materials to set a new standard of quality. AUTO-EXTREME Technology ensures consistent graphics card quality as well as improved performance and longevity. This new manufacturing process is also environmentally friendly, eliminating harsh chemicals and reducing power consumption by 50%.
8-phase Super Alloy Power II
ASUS engineers have integrated aerospace-grade alloy components into their graphics card designs to reinforce overall reliability. Super Alloy Power II components greatly enhance efficiency, reduce power loss, provide 2X reduced component buzzing while under full load, and achieve thermal levels that are approximately 50% cooler than previous designs.
GPU Tweak II with XSplit Gamecaster
Tweak Till Your Heart's Content
Redesigned with an intuitive, all-new UI, GPU Tweak II makes overclocking easier and more visual than ever, while still retaining advanced options for seasoned overclockers. With one click, the new Gaming Booster function maximizes system performance by removing redundant processes and allocating all available resources automatically. XSplit Gamecaster lets you easily stream or record your gameplay right from a convenient, in-game overlay.
Product Description | ASUS STRIX-R9380-DC2OC-2GD5-GAMING - graphics card - Radeon R9 380 - 2 GB | Device Type | Graphics card | Bus Type | PCI Express 3.0 x16 | Graphics Engine | AMD Radeon R9 380 | Memory | 2 GB GDDR5 | Core Clock | 1010 MHz | Stream Processors | 1792 | Effective Memory Clock | 5.5 GHz | Memory Interface | 256-bit | Interfaces Details | DVI-I (dual link) , DVI-D (dual link) , DisplayPort , HDMI | API Supported | OpenGL 4.4 | Dimensions (WxDxH) | 4.2 cm x 27.1 cm x 13.9 cm | Microsoft Certification | Compatible with Windows 7 |
General | |
Features | Dual Slot Fan Cooler, Native HDMI, AMD Eyefinity Technology, AMD CrossFireX Technology, Graphics Core Next (GCN), ASUS DIGI+ VRM, ASUS DirectCU II with 0dB Fan Technology, Super Alloy Power II technology, AUTO-EXTREME technology, HDCP |
Memory | |
Size | 2 GB |
Technology | GDDR5 SDRAM |
Effective Clock Speed | 5.5 GHz |
Bus Width | 256-bit |
System Requirements | |
Additional Requirements | 8 pin PCI Express power connector |
Miscellaneous | |
Power Consumption Operational | 225 Watt |
Included Accessories | STRIX Laser Sticker |
Software Included | Display drivers, XSplit Gamecaster (1 year Premium licence), ASUS GPU Tweak II |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Width | 4.2 cm |
Depth | 27.1 cm |
Height | 13.9 cm |
