The ergonomically-designed PA238Q professional monitor comes with swivel, tilt, pivot, and height adjustments for ideal viewing position.
Product Description | ASUS PB238Q - LED monitor - Full HD (1080p) - 23" | Device Type | LED-backlit LCD monitor - 23" | Energy Class | Class B | Energy Consumption per Year | 25 kWh | Power Consumption (On mode) | 24 W | Features | USB 2.0 hub | Panel Type | IPS | Native Resolution | Full HD (1080p) 1920 x 1080 | Pixel Pitch | 0.2652 mm | Brightness | 250 cd/m² | Contrast Ratio | 80000000:1 (dynamic) | Response Time | 6 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | HDMI, DVI-D, VGA, DisplayPort | Speakers | Integrated | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 54.88 cm x 20.1 cm x 41.42 cm | Weight | 5.5 kg | Microsoft Certification | Compatible with Windows 7 | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, PSE Mark, GOST-R, J-MOSS, ERP |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23" |
Built-in Devices | USB 2.0 hub |
Panel Type | IPS |
Vertical Refresh Rate | 50 - 75 Hz |
Horizontal Refresh Rate | 24 - 83 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Controls & Adjustments | Volume, brightness, contrast, input select, colour temperature |
Features | HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale |
Colour | Black |
Dimensions (WxDxH) | 54.88 cm x 20.1 cm x 41.42 cm - with stand |
Weight | 5.5 kg |
Audio | |
Type | Speakers - stereo - integrated |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | VGA , DVI-D , Audio line-in , DisplayPort , HDMI , 4 x USB 2.0 downstream , USB 2.0 upstream (Type B) |
Mechanical | |
Tilt Angle | -5/+20 |
Swivel Angle | 120 |
Rotation Angle | 90 |
Height Adjustment | 100 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable , 1 x DVI cable , 1 x USB cable - USB Type A to B |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Power | |
Power Supply | Internal |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 33 Watt |
Power Consumption Stand by / Sleep | 0.5 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.5 Watt |
On / Off Switch | Yes |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 54.88 cm - depth: 5.76 cm - height: 32.37 cm |
Sustainability Information | |
ENERGY STAR Certified | Yes |
