ASUS Dual series of GeForce GTX 1060 comes equipped with wing-blade fans for max air flow with more air pressure. While Auto-Extreme technology with Super Alloy Power II components for superior stability. GPU Tweak II with XSplit Gamecaster provides intuitive performance tweaking and instant gameplay streaming.
Product Description | ASUS DUAL-GTX1060-3G - graphics card - GF GTX 1060 - 3 GB | Device Type | Graphics card | Bus Type | PCI Express 3.0 x16 | Graphics Engine | NVIDIA GeForce GTX 1060 | Memory | 3 GB GDDR5 | Core Clock | 1506 MHz | Boost Clock | 1708 MHz | CUDA Cores | 1152 | Effective Memory Clock | 8.008 GHz | Memory Interface | 192-bit | Max Resolution | 7680 x 4320 | Interfaces Details | DVI-D (dual link) , 2 x HDMI , 2 x DisplayPort | API Supported | DirectX 12, OpenGL 4.5 | Dimensions (WxDxH) | 4.3 cm x 24.2 cm x 13 cm |
General | |
CUDA Cores | 1152 |
VR Ready | Yes |
Features | Native HDMI, Dual Fan Design, NVIDIA G-Sync ready, NVIDIA GameWorks, Super Alloy Power II technology, AUTO-EXTREME technology, Nvidia GeForce GTX VR Ready, Wing-Blade Fans, NVIDIA Ansel, HDCP |
Memory | |
Size | 3 GB |
Technology | GDDR5 SDRAM |
Effective Clock Speed | 8.008 GHz |
Bus Width | 192-bit |
System Requirements | |
Additional Requirements | 6 pin PCI Express power connector |
Miscellaneous | |
Software Included | Display drivers, ASUS GPU Tweak II, XSplit Gamecaster 2 (1 year Premium licence) |
Width | 4.3 cm |
Depth | 24.2 cm |
Height | 13 cm |
