Powered by the next generation Intel Celeron Processor N2807 are significantly faster and more efficient. They deliver easy multitasking and enhanced performance. The EeeBox PCs feature D-sub and HDMI output ports with dual display support. On two separate screens make you more productive. The ASUS EeeBox features a sleek design and extremely light weight. ASUS EeeBox is simple, chic, and even thinner than a book!
Fan-less design: Enjoy a silent working environment, increased system reliability, and save on energy costs.
1-liter sized chassis with rotatable VESA-mount to maximize workspaces and placement flexibility.
Long life cycle (> 3 years).
Windows OS allows you to create customized intelligent solutions to your business requirements.
Full compatibility with a wide range of business peripherals; features a 4-in-1 card reader, USB3.0, USB2.0, HDMI, VGA, and COM ports.
Product Description | ASUS Eee Box E210 - mini PC - Celeron N2807 1.58 GHz - 2 GB - SSD 32 GB | Type | Thin client - mini PC | Processor | 1 x Intel Celeron N2807 / 1.58 GHz (, up to 2.16 GHz, (Dual-Core) | Cache Memory | 1 MB | Cache Per Processor | 1 MB | RAM | 2 GB (installed) / 4 GB (max) - DDR3L SDRAM | Hard Drive | SSD 32 GB | Optical Storage | No optical drive | Card Reader | 4 in 1 | Graphics Controller | Intel HD Graphics | Audio Output | Stereo | Networking | GigE, 802.11b/g/n | OS Provided | Microsoft Windows Embedded Standard 7 64-bit | Colour | Black | Dimensions (WxDxH) | 2.9 cm x 17.25 cm x 21.9 cm | Weight | 690 g | Environmental Standards | ENERGY STAR Qualified |
General | |
Type | Thin client |
Product Form Factor | Mini PC |
Built-in Devices | Antenna |
Colour | Black |
Processor / Chipset | |
CPU | Intel Celeron N2807 |
Clock Speed | 1.58 GHz |
Max Turbo Speed | 2.16 GHz |
Number of Cores | Dual-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
Cache Memory | |
Installed Size | 1 MB |
RAM | |
Installed Size | 2 GB / 4 GB (max) |
Technology | DDR3L SDRAM |
Effective Memory Speed | 1600 MHz |
Form Factor | SO-DIMM 204-pin |
Slots | 1 (Total) / 0 (empty) |
Configuration Features | 1 x 2 GB |
Hard Drive | |
Type | SSD |
Capacity | 1 x 32 GB |
Optical Storage | |
Type | No optical drive |
Card Reader | |
Type | 4 in 1 card reader |
Supported Flash Memory Cards | MultiMediaCard, SD Memory Card, SDHC Memory Card, SDXC Memory Card |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel HD Graphics |
Video Interfaces | VGA, HDMI |
Audio Output | |
Sound Output Mode | Stereo |
Compliant Standards | High Definition Audio |
Networking | |
Wireless LAN Supported | Yes |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n |
Expansion / Connectivity | |
Slots | 1 (total) / 0 (free) x SO-DIMM 204-pin |
Interfaces | 3 x USB 2.0 (3 in front) , 1 x USB 3.0 (1 in front) , 1 x microphone - mini-jack (1 in front) , 1 x headphones - mini-jack (1 in front) , 1 x VGA output , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 1 x serial |
Miscellaneous | |
Included Accessories | Vertical stand, VESA mounting kit |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
VESA Mounting Interface | Yes |
Compliant Standards | CSA, UL, BSMI, CB, FCC |
Power | |
Device Type | Power adapter |
Power Consumption Stand by | 6.36 Watt |
Operating System / Software | |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Dimensions & Weight | |
Width | 2.9 cm |
Depth | 17.25 cm |
Height | 21.9 cm |
Weight | 690 g |
