ASUS HD 7990: dual-GPU power for an ultra-gaming future
Graphics GPU Features
Product Description | ASUS HD7990-6GD5 - graphics card - 2 GPUs - Radeon HD 7990 - 6 GB | Device Type | Graphics card | Bus Type | PCI Express 3.0 x16 | Graphics Engine | 2 GPUs - AMD Radeon HD 7990 | Memory | 6 GB GDDR5 | Core Clock | 1000 MHz | Effective Memory Clock | 6 GHz | Memory Interface | 2 x 384-bit | Max Resolution | 2560 x 1600 | Max Monitors Supported | 6 | Interfaces | DVI-I (dual link) , 4 x Mini DisplayPort , HDMI - with adapter | API Supported | DirectX 11.1 | Dimensions (WxDxH) | 3.7 cm x 30.48 cm x 11.11 cm | Microsoft Certification | Compatible with Windows 7 |
General | |
Features | AMD Eyefinity Technology, AMD HD3D Technology, AMD CrossFireX Technology, HDCP |
Memory | |
Size | 6 GB |
Technology | GDDR5 SDRAM |
Effective Clock Speed | 6 GHz |
Bus Width | 2 x 384-bit |
System Requirements | |
Additional Requirements | 2 x 8 pin PCI Express power connector |
Miscellaneous | |
Power Consumption Operational | 375 Watt |
Cables Included | 1 x CrossFire cable , 1 x HDMI-DVI adapter , 1 x Mini DisplayPort-DVI adapter |
Software Included | Drivers & Utilities, ASUS GPU Tweak |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Width | 3.7 cm |
Depth | 30.48 cm |
Height | 11.11 cm |
