BT.com
Wishlist
Asus 970 PRO GAMING/AURA AMD AM3+ DDR3 USB3.1 M.2 ATX
Delivery
Standard Due date unavailable
World's first 970 AMD gaming board with official NVIDA® certification
Supports AMD® AM3+ FX™/Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors
NVIDIA® SLI™ and AMD® CrossFireX™ Support
Dual-channel DDR3 2133 support
Intel Gigabit Ethernet, LANGuard and GameFirst technology: Top-speed protected networking
SupremeFX: Flawless audio that makes you part of the game
Sonic Radar ll: Scan and detect your enemies to dominate
RAMCache: Speed up your game loads
Gamer's Guardian: Highly-durable components and smart DIY features
USB 3.1 Type-A and M.2: Ultra-speedy transfers for faster gaming
BRIGHTEN YOUR BUILD WITH CUSTOMIZABLE RGB LED ILLUMINATION
Gaming is about your style, your personality — and your passion. 970 Pro Gaming/Aura is the gaming motherboard that lets you inject passion to project your style and personality in full color! Aura, our all-new LED-illumination technology, lighting up an endless spectrum of color combinations coupled with a selection of fascinating and fun effects.
EPIC GRAPHICS SUPPORTS FOR EPIC GAMING EXPERIENCES
970 Pro Gaming/Aura is the planet's first AMD 970 chipset-based motherboard to receive official certification for compatibility with NVIDIA™ SLI™ for truly epic graphics and gaming. It also supports AMD® CrossfireX™ . So, choose your weapon for up to two-way, quad-GPU graphics supremacy — and give your 970 Pro Gaming/Aura rig maximum gaming performance, visual excellence and gameplay thrills!
ASUS 970 PRO GAMING/AURA - motherboard - ATX - Socket AM3+ - AMD 970
Motherboard - ATX
Chipset Type
AMD 970 / AMD SB950
Processor Socket
1 x Socket AM3+
Compatible Processors
Sempron, Phenom II X3, Athlon II X2, Phenom II X2, Athlon II X4, Athlon II X3, Phenom II X4, Phenom II X6, FX
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID), 1 x M.2
USB / FireWire Ports
2 x USB 3.1 + 8 x USB 2.0 + (2 x USB 3.0 + 6 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
AMD 970 / AMD SB950
Processor Socket
Socket AM3+
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz, 2133 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Audio
Audio Codec
SupremeFX
High Definition Audio
LAN
Network Controller
Intel I211-AT
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 2 x PCIe 2.0 x16 (dual x8 mode; single card: x16 mode) , 2 x PCIe 2.0 x1 , 2 x PCI
Storage Interfaces
AMD SB950: SATA-600 / PCIe 3.0 -connectors: 6 x 7pin Serial ATA, 1 x M.2 - RAID 0 / RAID 1 / RAID 10 / RAID 5
1 x PS/2 keyboard / mouse , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.1 , 8 x USB 2.0 , 1 x TOSLINK , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (side surround) - mini-jack
Internal Interfaces
6 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header , 1 x serial - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, UEFI BIOS, SMBIOS 2.7 support
Sleep / Wake Up
Wake on LAN (WOL), wake on PME
Hardware Features
AMD Cool 'n' Quiet Technology, jack retasking, ASUS Q-Design, GameFirst, ESD Guards, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, audio jack detect technology, ASUS Q-Shield, NVIDIA Quad SLI Technology Support, ASUS DIGI+ VRM, SupremeFX Shielding technology, AMD Quad CrossFireX technology support, ASUS Fan Xpert 2, Disk Unlocker, Hyper Transport 3.0, ASUS Enhanced DRAM Overcurrent Protection, Preboot eXecution Environment (PXE), ASUS Stainless Steel Back I/O, ASUS O.C. Tuner, LANGuard, Sonic Radar II, USB 3.1 Boost, ASUS Gamer's Guardian, AURA RGB Lighting Control
Cable ties, I/O back plate, cable labels, 1 x M.2 screw
2 x Serial ATA cable , 1 x SLI bridge
Software Included
Drivers & Utilities, ASUS EZ Flash 2, ASUS AI Charger+, ASUS AI Suite III, ASUS EZ Update, Antivirus (OEM version), Media Streamer, ASUS RAMCache
Plug and Play, ACPI 2.0a
30.5 cm
24.4 cm
Scroll to top
