Answer a call from your surfboard. Stream your favorite songs on your run. And do it all while leaving your phone behind. The Apple Watch Series 3 gives you the freedom to go with just your watch.
Product Description | Apple Watch Series 3 (GPS + Cellular) - gold aluminium - smart watch with sport band - pink sand - 16 GB | Product Type | Smart watch | Tracking Data | Distance, time, calories burned, activity, heart rate, steps taken | Connectivity | Wi-Fi, Bluetooth 4G | Navigation | GPS/GLONASS/Galileo/QZSS receiver | Display | OLED 272 x 340 pixels - Ion-X glass | Processor | Apple S3 | Storage | 16 GB | Operating System | WatchOS 4 | Case | 38 mm - anodised aluminium | Band | Pink sand - sport band - fluoroelastomer | Intelligent Assistant | Siri | Input | Force Touch | Fits Wrist with Circumference | 130-200 mm | Notifications | Calendar, SMS, Email | Features | Call handling, music remote handling, camera remote control, listening to music, Retina Display technology, text messages handling | Supported Host Device OS | iOS | Battery | Lithium Ion | Battery Run Time | Up to 18 hours | Dimensions (WxDxH) | 33.3 mm x 11.4 mm x 38.6 mm | Weight | 28.7 g | Specific Absorption Rate (SAR) | 0.14 W/kg (head) , 0.15 W/kg (limb) |
General | |
Supported Host Device OS | iOS 11 or later |
Supported Mobile Messaging Services | SMS |
Audio Input | Microphone |
Audio Output | Speaker |
Wearing Style | Watch style |
Clock Display | Yes |
Set Goals | Yes |
Sensors | Accelerometer, ambient light sensor, gyro sensor, heart rate, barometric altimeter |
Cellular | |
Mobile Broadband Generation | 4G |
Service Provider | Not specified |
SIM Card Type | Electronic SIM card (e-SIM) |
Storage | |
Capacity | 16 GB |
Display | |
Type | OLED - colour |
Resolution | 272 x 340 pixels |
Protection | Ion-X glass |
Connectivity | |
Wireless Interface | IEEE 802.11b/g/n, Bluetooth 4.2 |
Input Device | |
Type | Touch sensitive screen (Force Touch) |
CPU | |
Manufacturer | Apple |
Type | S3 |
Features | W2 Apple wireless chip |
Battery | |
Technology | Lithium Ion |
Run Time (Up To) | 18 hours |
Smart Watch Case | |
Case Size | 38 mm |
Crown Type | Digital |
Case Back | Ceramic back |
Case Details | Gold aluminium |
Band | |
Name | Sport band |
Clasp Type | Pin-and-tuck |
Material | Fluoroelastomer |
Colour | Pink sand |
Dimensions & Weight | |
Width | 33.3 mm |
Depth | 11.4 mm |
Height | 38.6 mm |
Weight | 28.7 g |
Internet of Things (IoT) | |
Miscellaneous | |
Preloaded Software | Siri |
Vibrating Alert | Yes |
Body Material | Anodised aluminium |
Protection | Waterproof |
Included Accessories | Power adapter, magnetic charging cable |
Environmental Parameters | |
Max Depth of Water Resistance | 50 m |
