Because it's made from a custom high-performance fluoroelastomer, the Sport Band is durable and strong, yet surprisingly soft. The smooth, dense material drapes elegantly across your wrist and feels comfortable next to your skin. An innovative pin-and-tuck closure ensures a clean fit.
Product Description | Apple Digital AV Multiport Adapter - adapter - HDMI / USB | Cable | Adapter - HDMI / USB | Max Output Resolution | 3840 x 2160 - 60 Hz | Connectors | 24 pin USB-C - male | Connectors (Second End) | HDMI - female , USB - female , USB-C (power only) - female | Compliant Standards | Thunderbolt 3 | Features | 4K support |
General | |
Cable Type | Adapter 4K support |
Interface Supported | HDMI / USB |
Adapters & Converters | |
Max Output Resolution | 3840 x 2160 |
Refresh Rate | 60 Hz |
Connectivity | |
Connectors (Second End) | 19 pin HDMI Type A - female , 4 pin USB Type A - female , 24 pin USB-C (power only) - female |
