The colourful, clip-and-go iPod shuffle. With buttons, VoiceOver and playlists, it's got all the greatest hits
Even the iPod shuffle clip gets the rock star treatment. Now forged in stainless steel, the clip attaches securely to your shirt, jacket, workout gear, even your backpack. And the sleek, durable, anodized aluminum case - makes iPod shuffle a wardrobe essential.
You've probably made multiple playlists in iTunes. With the iPod shuffle, you can sync your playlists and always find the perfect mix for your activity or mood. VoiceOver tells you the name of each playlist, so it's easy to switch between them and find the one you want without looking.
The shuffle switch has three positions. Flip it to the left, and your music shuffles for a "whatever happens, happens" flow. Flip it to the middle, and your songs play in order. Or flip to the right to turn it off.
Sleek, anodised aluminium. In a full spectrum of colours
Its main body is crafted from a single piece of aluminium, so iPod shuffle feels solid, sleek and durable. And the colour palette makes it the perfect fashion accessory.
Hundreds of songs to go
Never leave a favourite tune behind. Along with up to 15 hours of battery life,1 iPod shuffle gives you 2GB of storage capacity, enough for hundreds of songs.2 That's plenty of room for the essential songs of your workout or commute. And for multiple playlists, Genius Mixes, podcasts and audiobooks too.
Goes anywhere. And with anything
iPod shuffle isn't just portable. It's wearable too. Clip it to your shirt, jacket, workout gear, backpack or purse strap, and it stays put -- whether you're running an errand or running round the track
Control your music with just a click
The big, clickable control pad on the front of iPod shuffle makes it easy to see and use the music controls. Press the centre button to play and pause. Press the outer buttons to skip forward or back and adjust volume. Click, click, click. It's music to your fingers.
Play it your way
Maybe you're the spontaneous type. Or maybe you prefer a little order. Just flip the shuffle switch to suit your listening style. Flip it to the left, and you'll hear your music in a refreshingly random way. Flip it to the middle, and your songs play in order. Or flip to the right to turn iPod shuffle off.
Give your songs a voice
Say you're listening to a song and want to know the title or the artist. Just press the VoiceOver button on top of your iPod shuffle, and it tells you.3 You can even use VoiceOver to hear the names of playlists and switch between them. And if your battery needs charging, VoiceOver tells you that too
It speaks your language
A French love song. A Spanish bolero. An Italian cantata. Your music library has songs from all over the world. That's why VoiceOver speaks 29 different languages. So it can tell you song titles and artists in their native tongues or any language you choose.
Sync to your heart's content
iTunes on your Mac or PC makes it easy to load up your iPod shuffle. Just choose the playlists, audiobooks, podcasts and other audio files you want, then sync.
When one playlist isn't enough
You probably have multiple playlists in iTunes on your computer. One for your commute. One for the gym. Sync those playlists to iPod shuffle, and you can play the perfect mix for whatever mood strikes you. VoiceOver tells you the name of each playlist, so it's easy to switch between them and find the one you want without looking.
Have Genius call the tunes
There's another way to get a good mix of music on iPod shuffle: let Genius do the work. Activate Genius in iTunes on your computer, and it automatically finds songs that sound great together. Then it creates Genius Mixes, which you can easily sync to your iPod shuffle. It's the perfect way to rediscover songs you haven't listened to in ages.
Product Description | Apple iPod shuffle - digital player | Product Type | Digital player flash based | Enclosure Colour | Blue | Dimensions (WxDxH) | 3.16 cm x 0.87 cm x 2.9 cm | Weight | 12.5 g | Playback Digital Standards | WAV, AAC, AIFF, Audible, MP3, Apple Lossless, Audible AAX, Audible AAX+, protected AAC | Sound Output Mode | Stereo | iPod Generation | 4G | Audio Specifications | Digital Player - response bandwidth: 20 - 20000 Hz | Internal Memory | 2 GB | Headphones | Headphones - binaural - ear-bud - stereo | Interface | USB 2.0 | Battery | Rechargeable - Lithium Ion | Manufacturer Warranty | 1-year warranty |
General | |
Product Type | Digital player |
Digital Player Type | Flash based |
Enclosure Material | Aluminium |
Interface Supported | USB 2.0 |
Audio Formats | WAV, AAC, AIFF, Audible, MP3, Apple Lossless, Audible AAX, Audible AAX+, protected AAC |
Audio System | |
File System Supported | 2 GB |
Functions | Digital player |
Audio Specifications | Digital Player - response time: 20 - 20000 Hz |
Features | USB 2.0 compatibility, VoiceOver, built-in clip |
Digital Player (Recorder) | |
Supported Bit Rate | 8 - 320Kbps |
Features | Variable bit-rate compatible |
Headphones | |
Headphones Type | Headphones - binaural - ear-bud |
Connectivity Technology | Wired |
Frequency Response | 20 - 20000 Hz |
Impedance | 32 Ohm |
Connections | |
Connector Type | Headphones (mini-phone stereo 3.5 mm) |
Miscellaneous | |
Included Accessories | USB adapter cable |
Battery | |
Integrated Battery | Rechargeable - Lithium Ion |
Run Time (Up To) | 15 hour(s) |
Recharge Time | 3 hour(s) |
System Requirements | |
OS Required | Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows XP Professional SP3, Microsoft Windows XP Home Edition SP3, Apple MacOS X 10.6.8 or later |
Software Requirements | iTunes 10.7 or later |
Additional Requirements | USB port (compatible with 2.0 specification) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year , Technical support - phone consulting - 90 days |
Dimensions & Weight | |
Width | 3.16 cm |
Depth | 0.87 cm |
Height | 2.9 cm |
Weight | 12.5 g |
