This silicone case protects the back of your tablet and fits snugly over the buttons without adding bulk. The soft microfiber lining helps protect your device, while the silky, soft-touch silicone exterior feels great in your hand.
Product Description | Apple - back cover for tablet | Product Type | Back cover for tablet | Material | Silicone | Colour | Charcoal grey | Designed For | 12.9-inch iPad Pro (1st generation, 2nd generation) |
General | |
Lining Material | Microfibre |
Carrying Case | |
Type | Protective cover |
Recommended Use | For tablet |
Cover Type | Back cover |
Compatibility Information | |
Designed For | Apple 12.9-inch iPad Pro (1st generation, 2nd generation) |
