The new sound of home
HomePod is a powerful speaker that sounds amazing, adapts to wherever it’s playing, and together with Apple Music, gives you effortless access to one of the world’s largest music catalogs. All controlled through natural voice interaction with Siri. It takes the listening experience to another level. And that’s just the beginning.
A breakthrough speaker all round
We completely reimagined how music should sound in the home. HomePod combines Apple-engineered audio technology and advanced software to deliver the highest-fidelity sound throughout the room, anywhere it’s placed. This elegantly designed, compact speaker totally rocks the house.
Deep bass. Engineered to lower the boom.
We built the high-excursion woofer with a custom amplifier to play a wide range of deep, rich bass. A powerful motor drives the diaphragm a full 20 millimetres — remarkable for a speaker this size. Meanwhile, HomePod uses an advanced algorithm that continuously analyses the music and dynamically tunes the low frequencies for smooth, immersive sound.
Seven tweeters. Amazing sound from every angle.
HomePod has a unique array of seven beamforming tweeters. Each with its own amplifier and transducer. And each custom designed with a precision acoustic horn that focuses sound for tremendous directional control. Creating an all-encompassing sense of space — and consistent, high-fidelity audio everywhere in the room.
A8 chip. The biggest brain ever in a speaker.
An Apple-designed A8 chip powers the most complex audio innovations in HomePod. Like real-time modelling of the woofer mechanics. Buffering that’s even faster than real time. Upmixing of both direct and ambient audio. Beamforming so the microphone can hear you over the music. And advanced echo cancellation. So you get amazing sound without even thinking about it.
Beautiful design with a purpose.
HomePod is wrapped in a seamless mesh fabric designed for both aesthetic and acoustic performance. Available in white and space grey, it’s gorgeous from every angle — yet virtually transparent to the music. And at under 18 centimetres tall, it can fit anywhere in your home.
It’s easier than easy. It’s automatic.
Setting up HomePod is quick and magical. Simply plug it in and your iOS device will detect it. Equipped with spatial awareness, HomePod automatically adjusts to give you optimal sound — wherever it’s placed. It can even hear your requests from across the room while loud songs are playing. All you need to do is enjoy your music.
Senses the room and tunes the music. All by itself.
Place HomePod anywhere in the room. It automatically analyses the acoustics, adjusts the sound based on the speaker’s location, and separates the music into direct and ambient sound. Direct sound is beamed to the middle of the room, while ambient sound is diffused into left and right channels and bounced off the wall. So your music sounds amazing, wherever you are in the room.
Product Description | Apple HomePod - smart speaker | Product Type | Smart speaker | Localisation | United Kingdom | Speaker Type | 2-way - active | Interfaces | Wi-Fi, Bluetooth | Platform | Apple HomeKit | Intelligent Assistant | Siri - direct | AirPlay | Yes | Streaming Services | Apple Music | Audio Formats | WAV, AAC, AIFF, MP3, FLAC, Apple Lossless, protected AAC, HE-AAC v1, MP3 VBR | Speaker Details | Speaker - mono - active | Colour | White | Power | AC 100 - 240 V (50 - 60 Hz) | Dimensions (WxDxH) | 17.2 cm | Dimensions - Diameter | 14.2 cm | Weight | 2.5 kg | Designed For | iPhone SE (2nd generation) |
General | |
Features | Direct/ambient audio beamforming, automatic room-sensing technology |
Microphone | 6 microphones array |
Enclosure Colour | White |
Speaker System | |
Maximum Bit Rate Supported | 320 Kbps |
Amplifier | Integrated |
Interfaces | IEEE 802.11a/b/g/n/ac, Bluetooth 5.0 |
AirPlay | Yes |
Internet Streaming Services | Apple Music |
Controls | Volume, play/pause, next track, previous track |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub | Integrated |
Communications Type | Cloud |
Intelligent Assistant | Siri |
Voice Control | Direct |
Speaker System Details | |
Driver Details | 7 x tweeter driver - horn loaded , Woofer driver - 4" |
Power | |
Power Source | Integrated power supply |
Voltage Required | AC 100 - 240 V (50 - 60 Hz) |
Dimensions & Weight | |
Height | 17.2 cm |
Weight | 2.5 kg |
Compatibility Information | |
Designed For | Apple iPhone SE (2nd generation) |
