To create an iPad this huge, no detail was too small. From the way images are brought to life to its considerable versatility, it was pushed every aspect of what's possible with iPad to advanced heights. The end result, unmistakable the moment you begin using it, goes beyond a larger display. Unlike anything before it, iPad Pro is a far bigger experience.
Product Description | Apple 12.9-inch iPad Pro Wi-Fi + Cellular - 2nd generation - tablet - 512 GB - 12.9" - 3G, 4G | Product Type | Tablet | Display | 12.9" IPS TFT - LED backlight - 2732 x 2048 (264 ppi) - Multi-Touch | Processor | Apple A10X Fusion (6-core) - 64-bit | Storage | 512 GB | Cellular Technology | 3G, 4G | Cellular Protocols | GSM, UMTS, EDGE, CDMA 2000 1X EV-DO Rev. A, HSPA, HSPA+, LTE, DC-HSDPA, CDMA 2000 1X EV-DO Rev. B, LTE Advanced | Wireless Connectivity | 802.11a/b/g/n/ac, Bluetooth 4.2 | Rear Camera | 12 Megapixel focus: automatic | Front Camera | 7 Megapixel | Navigation System | A-GPS/GLONASS | Security Devices | Fingerprint reader | Battery Run Time | Up to 10 hours | Dimensions (WxDxH) | 22.06 cm x 0.69 cm x 30.57 cm | Weight | 692 g | Colour | Silver | Localisation | English / United Kingdom | Specific Absorption Rate (SAR) | 0.97 W/kg (body) | Manufacturer Warranty | 1-year warranty |
General | |
Operating System | Apple iOS 12 |
Display | |
Type | 12.9" IPS TFT - LED backlight |
Resolution | 2732 x 2048 (264 ppi) |
Touchscreen | Multi-Touch |
Features | Anti-glare, anti-reflective, anti-fingerprint, Retina display, fully laminated display, True Tone display, ProMotion technology |
Processor | |
Processor | Apple A10X Fusion |
Number of Cores | 6-core |
64-bit Computing | Yes |
Memory | |
Storage | 512 GB |
Communications | |
Band | GSM 850/900/1800/1900 / UMTS 850/900/1700/1900/2100 / CDMA 2000 X1 800/1900 / LTE 700/700 APT/700b/700c/700 de/800/ 800 DD/850/900/1500/1800/1900/TD 1900/2100/2300/TD 2300/TD 2500/2600/TD 2600/AWS |
Rear Camera | |
Sensor Resolution | 12 Megapixel |
Camera Zoom | 5x digital zoom |
Focus Adjustment | Automatic |
Lens Aperture | F/1.8 |
HDR Mode | Auto HDR mode |
Face Detection | Body and face detection |
Features | Sapphire crystal lens cover, Focus Pixels, Cinematic video stabilisation, Live Photo, Playback zoom, Hybrid IR filter, Exposure control, noise reduction, geotagging |
Front Camera | |
Sensor Resolution | 7 Megapixel |
Lens Aperture | F/2.2 |
Features | FaceTime HD camera |
Navigation System | |
Receiver | A-GPS/GLONASS |
Multimedia | |
Supported Digital Audio Standards | WAV, AAC, AIFF, Audible, MP3, Apple Lossless, AC-3, HE-AAC, Audible AAX, Audible AAX+, protected AAC, EAC3, MP3 VBR |
Supported Digital Video Standards | MPEG-4 SP (up to 640x480), Motion JPEG (up to 1280x720), H.264 High Profile Level 4.2 (up to 4K) |
Audio | Two microphones, four speakers |
Input Device | |
Software | |
Preloaded Software | Clock, Mail, Notes, Calendar, Contacts, Messages, Camera, Files, FaceTime, Photo Booth, Safari, Photos, App Store, Maps, News, Find My iPhone, Stocks, Siri, Books, Reminders, Music, Find My Friends, Voice Memos, iTunes Store, Podcasts, Apple TV App, Home, Measure |
System Requirements for PC Connection | |
OS Required | Microsoft Windows 7 or later, Apple MacOS X 10.9.5 or later |
Expansion and Connectivity | |
Interfaces | 1 x headphones mini jack (3.5mm) , 1 x Lightning , 1 x Smart Connector |
Battery | |
Technology | Lithium polymer |
Capacity | 41 Wh |
Run Time Details | Web browsing over Wi-Fi: up to 10 hour(s) , Video playback: up to 10 hour(s) , Audio playback: up to 10 hour(s) , Web browsing over cellular data network: up to 9 hour(s) |
Miscellaneous | |
Colour | Silver |
Sensors | Accelerometer, ambient light sensor, 3-axis gyro sensor, digital compass, barometer |
Features | Charging via USB, VoiceOver screen reader, AirPrint, AirPlay, parental controls, Dictation, AssistiveTouch, MIMO technology, AirDrop, iBeacon microlocation, Family Sharing, Night Shift, Apple M10 motion coprocessor |
Included Accessories | Power adapter |
Cables Included | Lightning to USB cable |
Dimensions & Weight | |
Width | 22.06 cm |
Depth | 0.69 cm |
Height | 30.57 cm |
Weight | 692 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year , Technical support - phone consulting - 90 days |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 5 - 95% (non-condensing) |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 45 °C |
Max Altitude Operating | 3 km |
