This model targets business and home office users alike. Hidden behind its classically designed case is the panel technology. It boasts a high typical contrast, Full HD resolution, a fast response time and wide viewing angles for amazing imaging performance.
Product Description | AOC Pro-line M2060PWDA2 - LED monitor - Full HD (1080p) - 19.53" | Device Type | LED-backlit LCD monitor - 19.53" | Energy Class | Class E | Power Consumption (On mode) | 13.4 W | Features | Stereo speakers | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Brightness | 250 cd/m² | Contrast Ratio | 3000:1 / 20000000:1 (dynamic) | Response Time | 7 ms | Colour Support | 16.7 million colours | Input Connectors | DVI, VGA | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Voltage | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) - with stand | 47.76 cm x 35.83 cm x 17.95 cm | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, TUV, RoHS | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 19.53" |
Built-in Devices | Stereo speakers |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Features | HDCP, i-Care |
Dimensions (WxDxH) | 47.76 cm x 35.83 cm x 17.95 cm - with stand |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | VGA , DVI |
Mechanical | |
Tilt Angle | -5/+22 |
Miscellaneous | |
Cables Included | 1 x VGA cable , 1 x DVI cable , 1 x audio cable |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 13.4 kWh/1000h |
Power Consumption (Typical) | 23 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption Sleep | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
