The 27-inch AOC E2770SH display was designed with speed in mind. The ultra-fast response time makes it perfect for passionate gamers, as well as anyone who uses graphics, animation and film editing applications. Simply connect your AV sources via the model's D-Sub, DVI or HDMI ports and enjoy flawless picture quality. The built-in speaks offer rich, clear sound for movies, music or video calls.
Product Description | AOC E2770SH - LED monitor - Full HD (1080p) - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class B | Features | Speaker | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.311 mm | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 / 20000000:1 (dynamic) | Response Time | 1 ms | Colour Support | 16.7 million colours | Input Connectors | HDMI, DVI, VGA | Display Position Adjustments | Tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) | 64.24 cm x 24.19 cm x 44.93 cm | Weight | 4.8 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, TUV GS, FCC, RoHS, TUV Bauart, EAC | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Built-in Devices | Speaker |
Panel Type | TN |
Vertical Refresh Rate | 50 - 76 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 170 |
Backlight Technology | WLED |
OSD Languages | Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean |
Features | HDCP, i-Menu, e-Saver technology, Screen+ |
Colour | Black |
Weight | 4.8 kg |
Audio | |
Type | Speakers |
Connectivity | |
Interfaces | DVI (HD-15) , VGA , HDMI , Audio line-in |
Mechanical | |
Tilt Angle | -5/+15 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | VESA interface support |
Included Accessories | Stand |
Cables Included | 1 x VGA cable , 1 x HDMI cable , 1 x audio cable |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 31 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.5 Watt |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
