This model targets business and home office users alike. Hidden behind its classically designed case is the LED technology. It boasts a high typical contrast, an ultra-fast response time and wide viewing angles for excellent imaging performance. With the i-Care function, the monitor adapts the panel's brightness to the ambient light. This means a more comfortable viewing experience, whilst lowering the energy consumption at the same time. The environmentally friendly display comes in an elegant, textured black finish.
Product Description | AOC Professional e2260Pwda - LED monitor - Full HD (1080p) - 21.5" | Device Type | LED-backlit LCD monitor - 21.5" | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.248 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 20000000:1 (dynamic) | Response Time | 5 ms | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Voltage | AC 90 - 240 V (50/60 Hz) | Dimensions (WxDxH) | 51.1 cm x 24.45 cm x 39.47 cm | Microsoft Certification | Compatible with Windows 7 | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | TUV GS, DDC-1, DDC-2B, FCC, DDC/CI, RoHS, ISO 9241-307 | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 21.5" |
Vertical Refresh Rate | 75 Hz |
Horizontal Refresh Rate | 80 kHz |
Video Bandwidth | 148.5 MHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | WLED |
Features | HDCP, Eco-Mode, e-Saver technology |
Audio | |
Type | Speakers |
Connectivity | |
Interfaces | VGA , DVI-D (HDCP) , Headphones |
Mechanical | |
Tilt Angle | -5/+15 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable , 1 x DVI cable , 1 x audio cable |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Power | |
Input Voltage | AC 90 - 240 V (50/60 Hz) |
Power Consumption (Typical) | 18 Watt |
Power Consumption Stand by / Sleep | 0.5 Watt |
Power Consumption Stand by | 0.3 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities, Screen+, I-Menu |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
