The AOC 919Vz offers premium picture quality for graphics-intensive applications. It comes with 10000:1 DCR contrast ratio, which delivers exceptional image clarity, and 170-degree viewing angle to provide increased visibility from side viewpoints. Its response time is 2ms, a key feature that prevents fast moving objects from becoming blurred. The AOC 919Vz offer consumers brilliant large screen performance.
Product Description | AOC 919Vz - LCD monitor - 19" | Device Type | LCD monitor - 19" | Panel Type | TN | Aspect Ratio | 5:4 | Native Resolution | 1280 x 1024 at 75 Hz | Pixel Pitch | 0.294 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 60000:1 (dynamic) | Response Time | 2 ms | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA | Speakers | Integrated | Display Position Adjustments | Tilt | Voltage | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 40.9 cm x 21 cm x 41 cm | Weight | 3.8 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, GOST, cUL, DDC-1, DDC-2B, ISO 13406-2, FCC, DDC/CI, RoHS, TUV Bauart | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LCD monitor / TFT active matrix |
Diagonal Size | 19" |
Panel Type | TN |
Vertical Refresh Rate | 75 Hz |
Horizontal Refresh Rate | 80 kHz |
Horizontal Viewing Angle | 176 |
Vertical Viewing Angle | 176 |
Controls & Adjustments | Volume |
Features | HDCP, Eco-Mode, Dynamic Color Boost, i-Menu |
Weight | 3.8 kg |
Audio | |
Type | Speakers - stereo - integrated |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | VGA , DVI-D |
Mechanical | |
Tilt Angle | 25 |
VESA Mounting Interface | Yes |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable , 1 x audio cable |
Power | |
Power Supply | Internal |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 24 Watt |
Power Consumption Stand by / Sleep | 1 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
