The 24-inch E2460SD2 display features Full HD resolution for detailed imagery and a fast 1 ms response time that makes it suitable even for games or movies. Standard VGA and DVI-D connectors make this monitor ideal for a variety of office and home users.
Product Description | AOC e2460Sd2 - Value - LED monitor - Full HD (1080p) - 24" | Device Type | LED-backlit LCD monitor - 24" | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Pixel Pitch | 0.276 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 20000000:1 (dynamic) | Response Time | 1 ms | Input Connectors | DVI-D, VGA | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, TUV GS, FCC, RoHS, EAC | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Panel Type | TN |
Vertical Refresh Rate | 50 - 76 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 170 |
Backlight Technology | LED backlight |
Features | HDCP, i-Menu, e-Saver technology, Screen+, i-Care |
Colour | Black |
Connectivity | |
Interfaces | VGA , DVI-D |
Mechanical | |
VESA Mounting Interface | Yes |
Miscellaneous | |
Features | Wall mountable |
Cables Included | 1 x VGA cable , 1 x DVI cable |
Power | |
Power Supply | Internal |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 28 Watt |
Power Consumption Stand by | 0.29 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 56.54 cm - depth: 21.93 cm - height: 40.305 cm - weight: 4.64 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
