BT.com
Wishlist
Antec 350W Basiq VP350P ATX PSU
£36.75
6 in stock
£36.75
Add to wishlist
Delivery
Standard 3-5 working days
The VP350 is crafted for just three things: quality, performance and incredible value. This entry-level solution gives you everything you need in a power supply. No twinkle lights or glittery paint jobs - just a 120 mm fan for effective and quiet cooling, dual +12 V rails for amazingly stable power, and heavy-duty protection circuitry for peace of mind, no matter how demanding your system. All the features, none of the waste: for builders that is strictly business, the VP350 is strictly power.
Antec Basiq VP350P - power supply - 350 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.3/ EPS12V 2.91
1.5 kg
United Kingdom
Input Voltage
AC 220-240 V
Power Capacity
350 Watt
Cooling System
120 mm fan
15 cm x 14 cm x 8.6 cm
2 years warranty
United Kingdom
Input Voltage
AC 220-240 V
Input Voltage Margin
+ 10% / - 10%
Frequency Required
50 - 60 Hz + 10% / - 10%
Power Capacity
350 Watt
Output Current
+5V 18 A , +12V1 18 A , +12V2 18 A , -12V 0.3 A , +5VSB 2 A , +3.3V 20 A
MTBF
100,000 hours
Cooling System
120 mm fan
Overheat protection, over current protection, over voltage protection, overpower protection, dual 12V rails, short-circuit protection
TUV, C-Tick, GOST, CB, CCC, RoHS
2 years warranty
Service & Support Details
Limited warranty - parts and labour - 2 years
15 cm
14 cm
8.6 cm
1.5 kg
Scroll to top
