Marketing description is not available.
Product Description | Acer XF240YU - LED monitor - 23.8" | Device Type | LED-backlit LCD monitor - 23.8" | Energy Class | Class B | Energy Consumption per Year | 62 kWh | Adaptive-Sync Technology | AMD FreeSync | Features | USB 3.0 hub | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | 2560 x 1440 at 144 Hz | Brightness | 350 cd/m² | Contrast Ratio | 100000000:1 (dynamic) | Input Connectors | 2xHDMI, DVI-D, DisplayPort | Display Position Adjustments | Height, pivot (rotation) | Screen Coating | Anti-glare | Colour | Black | Dimensions (WxDxH) | 54.1 cm x 24.4 cm x 37.5 cm | Manufacturer Warranty | 2-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.8" |
Built-in Devices | USB 3.0 hub |
Panel Type | TN |
Backlight Technology | LED backlight |
Features | Acer EcoDisplay |
Colour | Black |
Connectivity | |
Interfaces | DVI-D (dual link) , 2 x HDMI , DisplayPort , 4 x USB 3.0 downstream , USB 3.0 upstream , Audio line-in/out |
Mechanical | |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | VESA interface support |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years - carry-in |
