The Veriton 2 series delivers excellent multitasking performance to optimize your productivity. Tool-less expandability, a selection of affordable solutions, and other useful features efficiently handle your daily work needs. With support for WOL, PXE and more, the Veriton 2 series is simple to manage.
Product Description | Acer Veriton X2 VX2640G - DTS - Core i5 7400 3 GHz - 4 GB - SSD 128 GB | Type | Personal computer - desktop slimline | Localisation | Region: United Kingdom | Processor | Intel Core i5 (7th Gen) 7400 / 3 GHz (, up to 3.5 GHz, (Quad-Core) | Processor Socket | LGA1151 Socket | Processor Main Features | Intel Turbo Boost Technology 2 | Cache Memory | 6 MB L3 Cache | Cache Per Processor | 6 MB | RAM | 4 GB (installed) / 16 GB (max) - DDR4 SDRAM | Storage Controller | SATA | Hard Drive | SSD 128 GB | Optical Storage | DVD-Writer | Graphics Controller | Intel HD Graphics 630 | Networking | 1GbE | Power | AC 120/230 V | OS Provided | Windows 10 Pro 64-bit Edition | Dimensions (WxDxH) | 10 cm x 35.4 cm x 26.5 cm | Weight | 6 kg |
General | |
Type | Personal computer |
Product Form Factor | Desktop slimline |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7400 |
Clock Speed | 3 GHz |
Max Turbo Speed | 3.5 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Socket | LGA1151 Socket |
Chipset Type | Intel H110 Express |
Cache Memory | |
Installed Size | L3 Cache - 6 MB |
RAM | |
Installed Size | 4 GB / 16 GB (max) |
Technology | DDR4 SDRAM |
Effective Memory Speed | 2400 MHz |
Rated Memory Speed | 2400 MHz |
Form Factor | DIMM 288-pin |
Features | Unbuffered |
Configuration Features | 1 x 4 GB |
Hard Drive | |
Type | SSD |
Capacity | 1 x 128 GB |
Storage Controller | |
Type | 1 x SATA |
Optical Storage | |
Type | DVD-Writer - SATA |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel HD Graphics 630 |
Video Interfaces | VGA, DVI |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Interface | USB |
Mouse | |
Interface | USB |
Networking | |
Ethernet Controller | Realtek RTL8111E |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Expansion / Connectivity | |
Bays | Internal 3.5" , External 5.25" |
Slots | 1 (total) / 0 (free) x CPU , DIMM 288-pin , 1 PCIe x1 , 1 PCIe x16 |
Interfaces | 4 x USB 2.0 (2 front, 2 rear) , 4 x USB 3.0 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) , 2 x microphone (1 in front) , 2 x audio line-out/headphones (1 in front) , 1 x audio line-in , 1 x serial , 1 x PS/2 keyboard , PS/2 mouse , 1 x DVI , 1 x VGA |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | EuP |
Power | |
Device Type | Power supply |
Voltage Required | AC 120/230 V |
Power Provided | 220 Watt |
Efficiency | 82%+ |
Power Factor Correction | Yes (active) |
Operating System / Software | |
Dimensions & Weight | |
Width | 10 cm |
Depth | 35.4 cm |
Height | 26.5 cm |
Weight | 6 kg |
