The Veriton Z houses a Full HD webcam that rotates up to 180º from front-facing to rear-facing, requiring only the tap of a hotkey to flip the image. Flip it from 0º to 90º to capture everyone in a video conference or to 180º to capture a customer's picture. The webcam also retracts to provide better security by preventing unnecessary exposure of your office.
Intel Core processor provides impressive performance, for seamless productivity. The Full HD display with IPS technology delivers clear views from all angles. Attach an additional monitor via HDMI to expand your view and multitask efficiently.
Product Description | Acer Veriton Z4710G_Wtub - all-in-one - Core i3 4170 3.7 GHz - 4 GB - HDD 500 GB - LED 21.5" | Type | Personal computer - all-in-one | Localisation | Region: United Kingdom | Processor | Intel Core i3 (4th Gen) 4170 / 3.7 GHz (Dual-Core) | Processor Socket | LGA1150 Socket | Cache Memory | 3 MB | Cache Per Processor | 3 MB | RAM | 4 GB (installed) / 16 GB (max) - DDR3L SDRAM | Storage Controller | SATA | Hard Drive | HDD 500 GB - SATA 6Gb/s - 7200 rpm | Optical Storage | DVD SuperMulti | Card Reader | Yes | Monitor | 21.5" - LED - 1920 x 1080 (Full HD) | Graphics Controller | Intel HD Graphics 4400 | Networking | GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0 | Power | AC 120/230 V | OS Provided | Microsoft Windows 7 Professional 64-bit Edition / Windows 10 Pro 64-bit Edition Dual Load | Dimensions (WxDxH) | 41.5 cm x 6.88 cm x 53.24 cm | Weight | 8.5 kg |
General | |
Type | Personal computer |
Product Form Factor | All-in-one - with stand |
Embedded Security | Trusted Platform Module (TPM 1.2) Security Chip |
Processor / Chipset | |
CPU | Intel Core i3 (4th Gen) 4170 |
Clock Speed | 3.7 GHz |
Number of Cores | Dual-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Socket | LGA1150 Socket |
Chipset Type | Intel H81 |
Cache Memory | |
Installed Size | 3 MB |
RAM | |
Installed Size | 4 GB / 16 GB (max) |
Technology | DDR3L SDRAM |
Effective Memory Speed | 1600 MHz |
Form Factor | SO-DIMM 204-pin |
Configuration Features | 1 x 4 GB |
Hard Drive | |
Type | HDD |
Capacity | 1 x 500 GB |
Interface Type | SATA 6Gb/s |
Spindle Speed | 7200 rpm |
Storage Controller | |
Type | 1 x SATA |
Optical Storage | |
Type | DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA |
Card Reader | |
Type | Card reader |
Monitor | |
Monitor Type | LED |
Diagonal Size | 21.5" |
Native Resolution | 1920 x 1080 (Full HD) |
Widescreen Display | Yes |
Response Time | 5 ms |
Image Brightness | 250 cd/m² |
Image Contrast Ratio | 1000:1 |
Monitor Features | Anti-glare |
Graphics Controller | |
Graphics Processor | Intel HD Graphics 4400 |
Video Interfaces | VGA, HDMI |
Audio Output | |
Speakers Included | 2 x right / left channel |
Camera | |
Resolution (MP) | 2 Megapixel |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Interface | USB |
Mouse | |
Interface | USB |
Networking | |
Wireless LAN Supported | Yes |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0 |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0 |
Expansion / Connectivity | |
Slots | 1 (total) / 0 (free) x CPU , SO-DIMM 204-pin |
Interfaces | 2 x USB 3.0 , 4 x USB 2.0 , 1 x HDMI , 1 x VGA |
Power | |
Device Type | Power adapter |
Voltage Required | AC 120/230 V |
Power Provided | 150 Watt |
Power Factor Correction | Yes (active) |
Operating System / Software | |
Dimensions & Weight | |
Width | 41.5 cm |
Depth | 6.88 cm |
Height | 53.24 cm |
Weight | 8.5 kg |
