This PC is compact, but won't compromise on performance and expandability. With great manageability and security features, you'll be sure everything is under control.
Product Description | Acer Veriton X4650G - SFF - Core i5 7500 3.4 GHz - 8 GB - SSD 256 GB | Type | Personal computer - small form factor | Localisation | Region: United Kingdom | Processor | Intel Core i5 (7th Gen) 7500 / 3.4 GHz (, up to 3.8 GHz, (Quad-Core) | Processor Socket | LGA1151 Socket | Processor Main Features | Intel Turbo Boost Technology 2, Intel Smart Cache | Cache Memory | 6 MB | Cache Per Processor | 6 MB | RAM | 8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | SSD 256 GB | Optical Storage | DVD-Writer | Graphics Controller | Intel HD Graphics 630 | Networking | 1GbE | Power | AC 120/230 V | OS Provided | Windows 10 Pro 64-bit Edition | Dimensions (WxDxH) | 10 cm x 39.21 cm x 26.7 cm | Weight | 6 kg |
General | |
Type | Personal computer |
Product Form Factor | Small form factor |
Embedded Security | Trusted Platform Module (TPM 2.0) Security Chip |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7500 |
Clock Speed | 3.4 GHz |
Max Turbo Speed | 3.8 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Socket | LGA1151 Socket |
Chipset Type | Intel B250 |
Cache Memory | |
Installed Size | 6 MB |
RAM | |
Installed Size | 8 GB / 64 GB (max) |
Technology | DDR4 SDRAM - non-ECC |
Effective Memory Speed | 2400 MHz |
Rated Memory Speed | 2400 MHz |
Form Factor | DIMM 288-pin |
Slots | 4 (Total) / 3 (empty) |
Features | Unbuffered |
Configuration Features | 1 x 8 GB |
Hard Drive | |
Type | SSD |
Capacity | 1 x 256 GB |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Optical Storage | |
Type | DVD-Writer - SATA |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel HD Graphics 630 |
Video Interfaces | VGA, DVI, HDMI |
Input Device | |
Type | Keyboard |
Keyboard | |
Interface | USB |
Networking | |
Ethernet Controller | Realtek RTL8111EPV |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Expansion / Connectivity | |
Bays | 1 (total) / 0 (free) x external 5.25" x 1/2H , 1 internal 3.5" x 1/3H |
Slots | 1 (total) / 0 (free) x CPU , 1 PCIe x1 , 1 PCIe x16 , 4 (total) / 3 (free) x DIMM 288-pin |
Interfaces | 4 x USB 2.0 (2 front, 2 rear) , 6 x USB 3.0 (2 front, 4 rear) , 2 x microphone (1 front, 1 rear) , 2 x audio line-out/headphones (1 front, 1 rear) , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x audio line-in , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x HDMI , 1 x VGA , 1 x DVI |
Miscellaneous | |
Included Accessories | M.2 SSD vertical bracket |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | EuP |
Power | |
Device Type | Power supply |
Voltage Required | AC 120/230 V |
Power Provided | 220 Watt |
Efficiency | 82%+ |
Power Factor Correction | Yes (active) |
Operating System / Software | |
Dimensions & Weight | |
Width | 10 cm |
Depth | 39.21 cm |
Height | 26.7 cm |
Weight | 6 kg |
