The Veriton 4 series comes ready to fit an array of office spaces and business demands. The powerful processor maximizes your potential, as does the ability to use as many as three independent displays. Its capacitive memory delivers serious performance and effortless multitasking.
Product Description | Acer Veriton N4 VN4640G - tiny - Core i5 6400T 2.2 GHz - 4 GB - HDD 500 GB | Type | Personal computer - tiny | Localisation | Region: Germany | Processor | Intel Core i5 (6th Gen) 6400T / 2.2 GHz (, up to 2.8 GHz, (Quad-Core) | Processor Socket | LGA1151 Socket | Processor Main Features | Intel Turbo Boost Technology 2 | Cache Memory | 6 MB | Cache Per Processor | 6 MB | RAM | 4 GB (installed) / 16 GB (max) - DDR4 SDRAM | Storage Controller | SATA | Hard Drive | HDD 500 GB - SATA 6Gb/s - 5400 rpm | Optical Storage | No optical drive | Graphics Controller | Intel HD Graphics 530 | Networking | GigE | Power | AC 120/230 V (50/60 Hz) | OS Provided | Microsoft Windows 7 Professional 64-bit Edition / Windows 10 Pro 64-bit Edition Dual Load | Dimensions (WxDxH) | 19.2 cm x 20.4 cm x 3.32 cm | Weight | 1.5 kg |
General | |
Type | Personal computer |
Product Form Factor | Tiny |
Embedded Security | Trusted Platform Module (TPM 1.2) Security Chip |
Processor / Chipset | |
CPU | Intel Core i5 (6th Gen) 6400T |
Clock Speed | 2.2 GHz |
Max Turbo Speed | 2.8 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Socket | LGA1151 Socket |
Chipset Type | Intel H110 Express |
Cache Memory | |
Installed Size | 6 MB |
RAM | |
Installed Size | 4 GB / 16 GB (max) |
Technology | DDR4 SDRAM |
Effective Memory Speed | 2133 MHz |
Form Factor | SO-DIMM 260-pin |
Configuration Features | 1 x 4 GB |
Hard Drive | |
Type | HDD |
Capacity | 1 x 500 GB |
Interface Type | SATA 6Gb/s |
Spindle Speed | 5400 rpm |
Storage Controller | |
Type | 1 x SATA |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel HD Graphics 530 |
Video Interfaces | VGA, HDMI, DisplayPort |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Interface | USB |
Mouse | |
Interface | USB |
Networking | |
Wireless LAN Supported | Yes |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Expansion / Connectivity | |
Slots | 1 (total) / 0 (free) x CPU , SO-DIMM 260-pin , 1 PCIe x16 , 1 PCIe |
Interfaces | 4 x USB 3.0 (3 front, 1 rear) , 2 x USB 2.0 (2 rear) , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 1 x headphones/microphone , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DisplayPort , 1 x HDMI |
Miscellaneous | |
Included Accessories | VESA mounting kit |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | RoHS |
Power | |
Device Type | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 65 Watt |
Operating System / Software | |
Dimensions & Weight | |
Width | 19.2 cm |
Depth | 20.4 cm |
Height | 3.32 cm |
Weight | 1.5 kg |
