Essential series monitor features Acer eColor technology for striking visuals, and Acer ComfyView innovations that reduce glare for comfortable viewing. This sturdy monitor also has a wide array of ports, so you can connect many types of devices and do more at once. In addition, it utilizes eco-friendly features to save power and money.
Product Description | Acer V176Lb - LED monitor - 17" | Device Type | LED-backlit LCD monitor - 17" | Native Resolution | 1280 x 1024 | Brightness | 250 cd/m² | Contrast Ratio | 100000000:1 (dynamic) | Response Time | 5 ms | Colour Support | 16.7 million colours | Input Connectors | VGA | Display Position Adjustments | Tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - without stand | 36.9 cm x 5.5 cm x 30.87 cm | Weight | 2.2 kg | Environmental Standards | TCO Certified Displays 8, ENERGY STAR Qualified EPEAT Gold | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 17" |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | LED backlight |
Colour | Black |
Dimensions (WxDxH) | 36.9 cm x 5.5 cm x 30.87 cm - without stand |
Weight | 2.2 kg |
Connectivity | |
Interfaces | VGA |
Mechanical | |
Miscellaneous | |
Cables Included | 1 x VGA cable |
Power | |
Power Supply | Internal |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 13 Watt |
Power Consumption Stand by | 0.35 Watt |
Power Consumption Sleep | 0.45 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 36.9 cm - depth: 19.1 cm - height: 39.45 cm - weight: 2.6 kg |
Sustainability Information | |
TCO Certified | TCO Certified Displays 8 |
EPEAT Compliant | EPEAT Gold |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - carry-in |
