Ultra Short-throw Series projectors portray clear, large images even when positioned very close to the projection screen. This makes them ideal for use in education and business environments, as well as in small rooms.
Main Features
DLP technology.
Enables projecting 3D content via DLP Link Technology: Blu-Ray 3D supported.
One-touch "3D" button on remote control allows quick and easy access to the 3D functions.
Acer ColorBoost technology delivers vivid, life-like images.
High brightness and contrast ratio.
Versatile display modes enable optimum performance in any situation.
Lower power consumption and economy (ECO) mode extends lamp life.
Dynamic black / ExtremeEco functions help decrease lamp power consumption and further extend lamp life.
Acer EcoProjection Technology delivers Intelligent power management approach and physical efficiency improvement.
Manual focus/zoom projection lens.
2X digital zoom and pan move function.
Product Description | Acer U5220 - DLP projector - ultra short-throw - 3D | Device Type | DLP projector | 3D Capable | Yes (3D glasses sold separately) | Brightness | 3000 lumens | Contrast Ratio | 13000:1 (dynamic) | Resolution | XGA (1024 x 768) | Native Aspect Ratio | 4:3 | Colour Support | 1.07 billion colours | Lens | Ultra short-throw fixed lens | Bulb type | UHP 240 Watt | Bulb life cycle | Up to 3000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode | Video Input | S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G) | Video Modes | 480p, 720p, 1080i, 1080p, 480i, 576i, 576p | Speakers | Speaker(s) - integrated | Power | AC 120/230 V | Power Consumption Operational | 299 Watt | Dimensions (WxDxH) | 33.9 cm x 32.3 cm x 23.7 cm | Weight | 5.5 kg | Manufacturer Warranty | 3-year warranty |
General | |
Projector | |
Brightness (Reduced) | 2400 lumens |
Image Size | 152 cm - 305 cm |
Projection Distance | 0.23 m - 0.8 m |
Throw Ratio | 0.47:1 |
Digital Zoom Factor | 2x |
Resolution | XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized) |
Max Sync Rate (V x H) | 120 Hz x 100 kHz |
Features | BrilliantColor, Instant Pack Technology, DLP 3D Ready, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, 24p True Cinema, Acer ColorSafe II Technology, ColorBoost 3D Technology |
Lens | |
Type | Ultra short-throw fixed lens |
Lens Aperture | F/2.53 |
Keystone Correction Direction | Horizontal, vertical |
Vertical Keystone Correction | -15 / +15 |
Horizontal Keystone Correction | -15 / +15 |
Video Input | |
TV System | PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G |
Analogue video Signal | S-Video, composite video |
Video Interfaces | VGA, HDMI, composite video, S-Video, MHL |
Speakers | |
Type | Integrated |
Sound Output Mode | Stereo |
Output Power / Channel | 10 Watt |
Speakers | 2 x right / left channel |
Expansion / Connectivity | |
Interfaces | 1 x USB - 4 pin mini-USB Type B , 2 x Mobile High-Definition Link (MHL) / HDMI , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x network - RJ-45 (management) , 2 x audio line-in - mini-phone 3.5 mm , 1 x microphone input - mini-phone 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x USB - 4 pin USB Type A , 1 x serial RS-232 , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) |
Miscellaneous | |
Included Accessories | Wireless remote control |
Cables Included | 1 x VGA cable |
Power | |
Power Source | AC |
Voltage Required | AC 120/230 V |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.5 Watt |
Dimensions & Weight | |
Width | 33.9 cm |
Depth | 32.3 cm |
Height | 23.7 cm |
Weight | 5.5 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - carry-in , Limited warranty - lamp - 1 year |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Sound Emission | 33 dBA |
Sound Emission (Economic Mode) | 27 dBA |
