The Acer TravelMate notebook features dependable processing power, wide-ranging communication capabilities, and indispensable security solutions to empower mobile professionals like you. Designed to keep your business running, while you're on the move, this streamlined notebook boasts corporate-level manageability and convenient handling. An eco-friendly design and energy-conserving features help save cost, as well as the environment.
Product Description | Acer TravelMate P648-M-770B - 14" - Intel Core i7 - 6500U - 4 GB RAM - 128 GB SSD - UK | Product Type | Notebook | Operating System | Win 10 Pro 64-bit | Processor | Intel Core i7 (6th Gen) - 6500U / 2.5 GHz, up to 3.1 GHz / 4 MB Cache | Memory | 4 GB DDR4 (provided memory is soldered) | Storage | 128 GB SSD | Display | 14" LED backlight 1366 x 768 / HD | Graphics | Intel HD Graphics 520 | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet | Battery | 3-cell - up to 8 hours | Features | G-sensor | Dockable | Yes | Security | Trusted Platform Module (TPM) Security Chip, fingerprint reader | Colour | Black | Dimensions (WxDxH) | 32.87 cm x 23.55 cm x 2.12 cm | Weight | 1.7 kg | Localisation | Region: United Kingdom | Environmental Standards | - TCO Certified Notebooks 8, ENERGY STAR Qualified EPEAT Climate+ |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i7 (6th Gen) 6500U / 2.5 GHz |
Max Turbo Speed | 3.1 GHz |
Number of Cores | Dual-Core |
Cache | 4 MB |
64-bit Computing | Yes |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 4 GB (provided memory is soldered) |
Max RAM Supported | 20 GB |
Technology | DDR4 SDRAM |
Speed | 2133 MHz / PC4-17000 |
Rated Speed | 2133 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 1 |
Empty Slots | 1 |
Storage | |
Main Storage | 128 GB SSD M.2 2280 SATA 6Gb/s |
Display | |
Type | 14" |
LCD Backlight Technology | LED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 220 cd/m² |
Features | Anti-glare, ComfyView, Mercury free |
Audio & Video | |
Graphics Processor | Intel HD Graphics 520 |
Memory Allocation Technology | Shared Video Memory (UMA) |
Camera | Yes - 1280 x 720 |
Camera Features | HDR (High Dynamic Range), 720p HD movie recording |
Sound | Four speakers, two microphones |
Audio Features | Output: Acer TrueHarmony technology |
Input | |
Type | Keyboard, touchpad |
Keyboard Layout | UK |
Features | Multi-gesture touch pad, Acer FineTip keyboard |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Wireless Controller | Intel Dual Band Wireless-AC 7265 - M.2 Card |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I219-LM |
Battery | |
Technology | 3-cell lithium polymer |
Capacity | 54 Wh |
Run Time | Up to 8 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 65 Watt, 19 V |
Connections & Expansion | |
Interfaces Details | 2 x USB 3.0 , HDMI , LAN , VGA , Dock , Headphone/microphone combo jack , USB-C Gen 2 (supports Thunderbolt 3) , USB 3.0 (with power off charging) |
Memory Card Reader | Yes (SD Card, SDHC Card, SDXC Card) |
Miscellaneous | |
Colour | Black |
Integrated Options | G-sensor |
Dockable | Yes |
Features | Administrator password, system password, hard drive password, Disc Anti-Shock Protection System (DASP, MIMO technology, Acer Purified.Voice technology |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Included Accessories | Power adapter |
Compliant Standards | GS, HSF, ACPI 5.0 |
Localization | Region: United Kingdom |
Dimensions & Weight | |
Weight | 1.7 kg |
Sustainability Information | |
TCO Certified | - TCO Certified Notebooks 8 |
EPEAT Compliant | EPEAT Climate+ |
ENERGY STAR Certified | Yes |
