The TravelMate P2 series meets various business needs. With its powerful processor, this notebook is built tough for hard-core use.
Product Description | Acer TravelMate P238-M-57T0 - 13.3" - Intel Core i5 - 6200U - 4 GB RAM - 128 GB SSD - UK | Product Type | Notebook | Operating System | Win 10 Pro 64-bit | Processor | Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache | Memory | 4 GB DDR3L (1 x 4 GB) | Storage | 128 GB SSD | Display | 13.3" LED backlight 1366 x 768 / HD | Graphics | Intel HD Graphics 520 | Keyboard | UK | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet | Battery | 4-cell | Colour | Black | Dimensions (WxDxH) | 32.7 cm x 22.8 cm x 1.965 cm | Weight | 1.6 kg | Localisation | Region: United Kingdom | Environmental Standards | - TCO Certified Notebooks 9 EPEAT Climate+ |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i5 (6th Gen) 6200U / 2.3 GHz |
Max Turbo Speed | 2.8 GHz |
Number of Cores | Dual-Core |
Cache | L3 - 3 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 4 GB (1 x 4 GB) |
Max RAM Supported | 16 GB |
Technology | DDR3L SDRAM |
Speed | 1600 MHz |
Form Factor | SO-DIMM 204-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 128 GB SSD |
Display | |
Type | 13.3" |
LCD Backlight Technology | LED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 220 cd/m² |
Features | HDCP, anti-glare |
Audio & Video | |
Graphics Processor | Intel HD Graphics 520 |
Memory Allocation Technology | Shared Video Memory (UMA) |
Camera | Yes - 1280 x 720 |
Camera Features | HDR (High Dynamic Range), 720p HD movie recording |
Sound | Stereo speakers, microphone |
Audio Features | Output: Acer TrueHarmony technology |
Input | |
Type | Keyboard, touchpad |
Keyboard Layout | UK |
Features | Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Wireless Controller | Intel Dual Band Wireless-AC 7265 - M.2 Card |
Network Interface | Gigabit Ethernet |
Battery | |
Technology | 4-cell lithium polymer |
Capacity | 3270 mAh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 19 V |
Connections & Expansion | |
Interfaces Details | HDMI , LAN , 2 x USB 2.0 , USB 3.0 (with power off charging) , USB-C Gen 1 , Headphone output |
Memory Card Reader | Yes (SD Card) |
Miscellaneous | |
Colour | Black |
Features | Administrator password, system password, hard drive password, NIL Technology (Nanoimprint Lithography) |
Included Accessories | Power adapter |
Compliant Standards | ACPI 5.0 |
Localization | Region: United Kingdom |
Dimensions & Weight | |
Weight | 1.6 kg |
Sustainability Information | |
TCO Certified | - TCO Certified Notebooks 9 |
EPEAT Compliant | EPEAT Climate+ |
