Whether you're in the mood for work or play, the Switch One 10 has a mode for it. Choose from four modes - notebook mode for typing, pad mode for using touch, and tent and display modes for entertainment.
Product Description | Acer Switch One 10 SW1-011-166Z - 10.1" - Intel Atom x5 - Z8350 - 2 GB RAM - 64 GB eMMC - UK | Product Type | Tablet - with keyboard dock | Operating System | Win 10 Home 32-bit | Processor | Intel Atom x5 Z8350 / 1.44 GHz, up to 1.92 GHz / 2 MB Cache | Memory | 2 GB DDR3L (provided memory is soldered) | Storage | 64 GB eMMC | Display | 10.1" LED backlight touchscreen 1280 x 800 / WXGA | Graphics | Intel HD Graphics | Input Device | Touchpad, detachable keyboard | Keyboard | UK | Integrated Webcam | Yes | Networking | Bluetooth, 802.11b/g/n | Battery | 2-cell - up to 10 hours | Features | G-sensor | Dockable | Yes | Colour | Black, iron | Dimensions (WxDxH) - tablet | 25.9 cm x 18.05 cm x 0.965 cm | Weight | 680 g | Localisation | Region: United Kingdom | Environmental Standards | - EPEAT Climate+ |
General | |
Operating System | Windows 10 Home 32-bit Edition |
Processor / Chipset | |
CPU | Intel Atom x5 Z8350 / 1.44 GHz |
Max Turbo Speed | 1.92 GHz |
Number of Cores | Quad-Core |
Cache | L2 - 2 MB |
64-bit Computing | Yes |
Features | Intel Burst Technology |
Memory | |
RAM | 2 GB (provided memory is soldered) |
Technology | DDR3L SDRAM |
Storage | |
Main Storage | 64 GB eMMC |
Display | |
Type | 10.1" - IPS |
LCD Backlight Technology | LED backlight |
Touchscreen | Yes (multi-touch) |
Resolution | 1280 x 800 (WXGA) |
Widescreen | Yes |
Image Brightness | 300 cd/m² |
Features | HDCP, glare, CineCrystal |
Audio & Video | |
Graphics Processor | Intel HD Graphics |
Memory Allocation Technology | Shared Video Memory (UMA) |
Camera | Yes - 1600 x 1200 (rear), 1600 x 1200 (front) |
Resolution | 2 Megapixel (rear), 2 Megapixel (front) |
Camera Features | 720p HD movie recording |
Sound | Stereo speakers, microphone |
Input | |
Type | Touchpad, detachable keyboard |
Keyboard Layout | UK |
Features | Multi-gesture touch pad, Acer FineTip keyboard |
Communications | |
Wireless | Bluetooth, 802.11b/g/n |
Battery | |
Technology | 2-cell lithium polymer |
Capacity | 31.2 Wh |
Run Time | Up to 10 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 15 Watt, 5 V, 3 A |
Connections & Expansion | |
Interfaces Details | Micro-USB 2.0 , Micro-HDMI , Headphone/microphone combo jack , Dock , USB 2.0 (on keyboard dock) |
Memory Card Reader | Yes (microSD) |
Miscellaneous | |
Case Material | Anodised aluminium |
Integrated Options | G-sensor |
Dockable | Yes |
Features | Volume control |
Included Accessories | Power adapter |
Localization | Region: United Kingdom |
Dimensions & Weight | |
Weight | 680 g |
Dimensions (WxDxH) / Weight Details | 25.9 cm x 18.05 cm x 0.965 cm / 680 g - tablet , 25.9 cm x 19.26 cm x 2.065 cm / 1.26 kg - tablet with keyboard |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
