Can a machine be brilliant? The Aspire Switch 10 E series thinks so. With a LED display that reveals bright colors and crisp, clear text, it delivers a lifelike visual experience. The Gorilla Glass display protects against scratches and improves durability.
Product Description | Acer Aspire Switch 10 E SW3-016-17BJ - 10.1" - Intel Atom x5 - Z8300 - 2 GB RAM - 32 GB eMMC | Product Type | Tablet - with keyboard dock | Operating System | Win 10 Home 64-bit | Processor | Intel Atom x5 Z8300 / 1.44 GHz, up to 1.84 GHz / 2 MB Cache | Memory | 2 GB LPDDR3 (provided memory is soldered) | Storage | 32 GB eMMC | Display | 10.1" LED backlight touchscreen 1280 x 800 / WXGA | Graphics | Intel HD Graphics | Input Device | Touchpad, detachable keyboard | Integrated Webcam | Yes | Networking | Bluetooth, 802.11b/g/n | Battery | 2-cell - up to 12 hours | Dockable | Yes | Colour | Grey, black | Dimensions (WxDxH) - tablet | 26.2 cm x 18 cm x 1.095 cm | Weight | 630 g | Localisation | Region: United Kingdom | Environmental Standards | - EPEAT Climate+ |
General | |
Operating System | Windows 10 Home 64-bit Edition |
Processor / Chipset | |
CPU | Intel Atom x5 Z8300 / 1.44 GHz |
Max Turbo Speed | 1.84 GHz |
Number of Cores | Quad-Core |
Cache | 2 MB |
64-bit Computing | Yes |
Features | Intel Burst Technology |
Memory | |
RAM | 2 GB (provided memory is soldered) |
Technology | LPDDR3 SDRAM |
Storage | |
Main Storage | 32 GB eMMC |
Display | |
Type | 10.1" - IPS |
LCD Backlight Technology | LED backlight |
Touchscreen | Yes (10-point multi-touch) |
Resolution | 1280 x 800 (WXGA) |
Widescreen | Yes |
Image Aspect Ratio | 16:10 |
Image Brightness | 350 cd/m² |
Features | Glare, CineCrystal |
Audio & Video | |
Graphics Processor | Intel HD Graphics |
Memory Allocation Technology | Shared Video Memory (UMA) |
Camera | Yes - 1600 x 1200 (rear), 1600 x 1200 (front) |
Resolution | 2 Megapixel (rear), 2 Megapixel (front) |
Camera Features | 720p HD movie recording |
Sound | Stereo speakers, microphone |
Compliant Standards | High Definition Audio |
Input | |
Type | Touchpad, detachable keyboard |
Features | Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad |
Communications | |
Wireless | Bluetooth, 802.11b/g/n |
Wireless Controller | M.2 Card |
Battery | |
Technology | 2-cell lithium polymer |
Capacity | 30 Wh |
Run Time | Up to 12 hours |
Battery Run Time | Video playback: up to 12 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 10 Watt, 5.35 V, 2 A |
Connections & Expansion | |
Interfaces Details | Micro-USB 2.0 , Micro-HDMI , Headphone/microphone combo jack , Dock , USB 2.0 (on keyboard dock) |
Memory Card Reader | Yes (microSD, microSDHC, microSDXC) |
Miscellaneous | |
Dockable | Yes |
Features | Volume control, Acer BluelightShield technology |
Included Accessories | Power adapter |
Compliant Standards | ACPI 5.0 |
Localization | Region: United Kingdom |
Dimensions & Weight | |
Weight | 630 g |
Dimensions (WxDxH) / Weight Details | 26.2 cm x 18 cm x 1.095 cm / 630 g - tablet , 26.2 cm x 18 cm x 2.285 cm / 1.2 kg - tablet with keyboard |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
