Marketing description is not available.
Product Description | Acer R221Q - LED monitor - Full HD (1080p) - 21.5" | Device Type | LED-backlit LCD monitor - 21.5" | Energy Class | Class E | Energy Consumption per Year | 26 kWh | Power Consumption (On mode) | 13.4 W | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Brightness | 250 cd/m² | Contrast Ratio | 100000000:1 (dynamic) | Response Time | 4 ms (grey-to-grey) | Colour Support | 16.7 million colours | Colour Gamut | 72% NTSC | Input Connectors | HDMI, DVI, VGA | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Voltage | AC 100/240 V | Colour | Black | Dimensions (WxDxH) - with stand | 49.78 cm x 22.38 cm x 38.34 cm | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | MPR II | Manufacturer Warranty | 2-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 21.5" |
Panel Type | IPS |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Acer EcoDisplay, ComfyView, Zero Frame, Flicker-Less technology, Blue Light Filter technology, 72% NTSC colour gamut |
Colour | Black |
Dimensions (WxDxH) | 49.78 cm x 22.38 cm x 38.34 cm - with stand |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | VGA , DVI (HDCP) , HDMI , Audio line-out |
Mechanical | |
Tilt Angle | -5/+15 |
Miscellaneous | |
Cables Included | 1 x VGA cable |
Power | |
Input Voltage | AC 100/240 V |
Power Consumption SDR (On mode) | 13.4 kWh/1000h |
Power Consumption (Typical) | 22 Watt |
Power Consumption Stand by | 450 mW |
Power Consumption Sleep | 400 mW |
On / Off Switch | No |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 49.78 cm - depth: 3.34 cm - height: 30.16 cm , With stand - width: 49.78 cm - depth: 22.38 cm - height: 38.34 cm |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
